Gauge swap
Old Jan 20, 2012 | 04:54 PM
tysen86's Avatar
Gauge swap
Will this SR5 gauge cluster fit in my plain jane 91 pickup? If so, what gauges will work and which ones will I have to wire up?
http://www.ebay.com/itm/89-95-Toyota-truck-4runner-Speedometer-Cluster-163K-94-93-92-91-90-cable-/250975752501?pt=Motors_Car_Truck_Parts_Accessories &vxp=mtr&hash=item3a6f521135#ht_500wt_922
Old Jan 20, 2012 | 06:25 PM
drmix's Avatar
It will fit and everything will work but you need to get a sr5 oil pressure sensor. Make sure you install the sensor before starting the truck otherwise you will fry the cluster
Old Jan 20, 2012 | 07:17 PM
RMA's Avatar
RMA
i know the title in the ad has cable ..but ask the seller and be sure its a mechanical cluster because thats more and likely what you have ..electronic started in 92
Old Jan 20, 2012 | 07:29 PM
DeathCougar's Avatar
The part about the oil pressure sender is correct. However.....
THIS!!!
Verify what year it came from FIRST. If its from 92, 93, 94, or 95, NO it WILL NOT WORK. 95 4Runners have cables, but that speedo will NOT WORK in your 91 either. It must be 89, 90, or 91.
Also, if you have a 4Cyl and its from a V6 (or vise versa) The tach will NOT WORK CORRECTLY. The 4cyl and V6 tachs are different.
Old Jan 20, 2012 | 07:31 PM
tysen86's Avatar
I know that it has a cable speedo because he sent me a picture of the back of the cluster. I will find out what year and engine it came from.
Old Jan 21, 2012 | 05:08 AM
tysen86's Avatar
Well, how bout this one? One of the pics shows writing on the cluster that says 90 4runner, 22re.
http://cgi.ebay.com/ws/eBayISAPI.dll...#ht_6786wt_768
Old Jan 21, 2012 | 08:08 AM
If that is correct (what was written on there) then yes, it will work. Its cable driven, and its 4cyl
Old Jan 21, 2012 | 03:04 PM
tysen86's Avatar
Awesome!! Thanks fellas!!
80Truck
Oct 12, 2025 07:25 PM
Nickyodaman
Jul 27, 2015 12:13 AM
Logz808
Jul 26, 2015 07:09 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
Poncho0206
Jul 10, 2015 06:21 PM
