Alt. light flickers
Old Jan 4, 2012 | 04:06 PM
sechott's Avatar
Alt. light flickers
I noticed every once in a while my alt. light flashes real quick at idle. The engine doesn't miss, aftermarket volt meter reads over 14 and doesn't flicker. It will just flash maybe once a minute or not at all. It is so quick I had to deliberately sit and watch it to see what the light said. '88 DLX 3.0 5spd
Old Jan 4, 2012 | 05:15 PM
SoCal4Running's Avatar
I know this sounds stupid and maybe my truck is demented but mine does it when the master cylinder is low.
Not kidding
Old Jan 4, 2012 | 05:52 PM
donomite49's Avatar
alternator brushes? easy fix did mine a few years back.
Old Jan 4, 2012 | 06:04 PM
Swimmerboy2112's Avatar
Mine did that right before the alt died on me.
Old Jan 5, 2012 | 02:34 AM
sechott's Avatar
Thanks.
Old Jan 5, 2012 | 03:56 AM
TNRabbit's Avatar
Could also be a ground issue. The wiring, harnesses & connections/connectors are all getting old & brittle. Check all the major grounds (ECU, fusebox underhood, frame, engine, body, etc.).
Old Jan 6, 2012 | 01:57 AM
sechott's Avatar
That maybe the case rabbit, I would imagine the volt meter would flicker when it flashes.
Old Sep 20, 2012 | 04:35 AM
sechott's Avatar
Update, my alternator stopped charging, I replaced the brushes just 5 dollar fix. Bearings and relator seemed in good shape.
Old Sep 20, 2012 | 10:53 AM
scope103's Avatar
Originally Posted by sechott
... I would imagine the volt meter would flicker when it flashes.
Probably not (but you just determined that yourself!) An "automotive" voltmeter has lots of damping, if for no other reason than to keep the needle from jiggling on rough roads. I would be surprised if it reacted fast enough to catch anything you'd call a "flicker."
80Truck
Oct 12, 2025 07:25 PM
ashersullivan88yota
Jan 18, 2022 05:37 PM
AkitaDog
Sep 1, 2015 08:05 AM
PopsDad1
Jul 30, 2015 02:21 PM
Odin
Jul 15, 2015 09:28 PM
