3VZE Low Idle
Old Jan 6, 2012 | 02:52 PM
adamthedroog's Avatar
3VZE Low Idle
Hi
My truck runs perfectly fine when I first start it and even sometimes after I've stopped it then started it again. (For example if I stop to go into the store). But sometimes after a while when I start it up again it revs up to about 1000 rpm then drops to about 500 rpm. After I've driven it for a while after that happens it goes back to around 850 rpm like it should.
Old Jan 6, 2012 | 03:32 PM
rworegon's Avatar
Check all the vacuum hoses and intake tube for cracks/leaks. Vacuum leaks can cause the idle go weird.
Old Jan 6, 2012 | 07:13 PM
TNRabbit's Avatar
Also check that your oil dipstick is securely inserted & the oil fill cap is tight.
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
luckypig44
Jul 19, 2015 11:25 AM
kyletbert
Jul 17, 2015 11:39 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
