22RE Problem.
Old Jan 14, 2012 | 01:57 PM
Whooker23's Avatar
22RE Problem.
I put a timing cover gasket on my 22re and i didnt know i had broke the coil wire and when i went go start it something smoked. Well i put a new wire on it and now i have nothing. it's like i have a dead battery, but i have all lights but when i turn the key on no dummy lights come on or anything and the ignition just clicks. I am befuddled. Please and thank you to anyone that can help.
Old Jan 14, 2012 | 02:30 PM
Whooker23's Avatar
I don't have anything.. radio, dash lights, dummy lights, no ignition at all. I have a dome light and headlights though.
Old Jan 14, 2012 | 02:46 PM
Bassmastry101's Avatar
Hows your main fuse look?
Old Jan 15, 2012 | 06:12 AM
Whooker23's Avatar
Any more ideas?
Old Jan 15, 2012 | 06:31 AM
Did you check it? Did you connect everything back up?
Old Jan 15, 2012 | 07:12 AM
Whooker23's Avatar
yeah everything is connected, all the grounds and fuse doesnt look bad
Old Jan 15, 2012 | 07:22 AM
abecedarian's Avatar
fuses above the kick panel and under the hood are good?
wiring to the alternator is good?
cman1's Avatar
check the wire from your battery to your fuse box on the passengers side and make sure it has a good,solid connection.also check the ground wire on the back of the engine to the firewall....
Old Jan 15, 2012 | 01:39 PM
The original post points right at the main fuse. You said something was smoking..where was the smoke coming from? Sounds like you are getting power to the starter since you said ignition clicks..But is it your relay your hearing or the solenoid.
Break out a multimeter and start checking for juice starting from the battery to the fuse box under the hood, to the ecu, and to the fuse box under the dash. If you have power to your headlights and dome light then either there is a wire broken/shorted/grounded, or your main fuse is blown.
Check power to ECU with the switch on and see what you find.
Let us know what you find out.
Old Jan 15, 2012 | 05:46 PM
Whooker23's Avatar
I got it figured out. Thanks guys. Then I wasn't getting spark but now I am getting spark to the number 1 plug wire, but no fuel. Anymore ideas? I've checked all the grounds, and fuses for that.
Old Jan 16, 2012 | 03:59 AM
Awesome. What year was your truck?
How did you check to see you were not getting fuel?
Old Jan 17, 2012 | 11:22 AM
Whooker23's Avatar
It's a 94. I am thinking the ecm might be bad. The fuel pump is kicking on but i am not getting any backfire or anything. i think the ecm isnt letting injectors to spray or the crank sensor or anything to work.
JaredL
Mar 28, 2016 09:08 PM
Dennisx2
Aug 10, 2015 06:48 AM
Mrhoadley
Aug 4, 2015 06:08 PM
Dennisx2
Aug 4, 2015 01:26 PM
PlayAwhile
Jul 20, 2015 11:36 AM
