Painting entire vehicle with bed liner...help.
Sorry if this is in the wrong section (I did a quick search but yielding nothing), but I plan on painting my 1993 4Runner with bed liner this spring. So, naturally, I have a couple questions.
First, which is the best liner to use to achieve the smoothest surface possible? I was thinking of using Raptor because it seems like it finishes pretty smooth with a nice matte look.
And second, does this method affect the temperature of the engine? Will it run hotter? Should I consider a cold-air intake? Any help/advice/guidance would be MUCH appreciated. Thanks!
Smoothest bedliner is probably going to be rattlecan bedliner by rustoleum or duplicolor. It looks pretty good imo - there's a pic online somewhere of a VW golf coated in it and looks great. Personally I wouldn't put roll-on bedliner on the exterior because of the uneven application unless you do like 3-4 coats which will be very thick and look bad. Otherwise, something like lineX would be best, but not cheap.
I would go with the rattlecan because I'm familiar with it already and it can easily be touched up whereas the others aren't so easy. I don't think engine temps will be affected by the extra thickness of coating, but more from the color absorbing sun light and even then not by much, especially when moving.
jasonty
41
12-23-2018 01:00 PM
09-04-2015 09:27 AM
HookahRoo
07-20-2015 07:06 PM
