Location for U shaped coolant hose on back of head/block of 86 22RE?
Old Jan 13, 2012 | 08:04 PM
stanz's Avatar
I had my friendly local dealer order replacement coolant hoses for every hose on the block since all of mine look original on my 86 4runner 22re.
I can locate all but one small U-shaped hose:16261-35030 water bypass. Can someone advise on where this is located? I've been outside in the dark for 20 mins with a flashlight and cannot locate it.
If available, a pic would be even more helpful. Thanks!
Old Jan 13, 2012 | 08:58 PM
BLKNBLU's Avatar
It's buried under the EFI stuff. Kinda between the throttle body and the cylinder head. You're probably better off feeling for it with your hands and then looking up from underneath the engine. This pic doesn't show it but kind of where it is.
http://personal.utulsa.edu/~nathan-b...47descript.pdf
In where those twisty tubes behind the water pump in the drawing.
I'll poke around for something better but that ought to get you started.
Good luck.
Old Jan 13, 2012 | 09:28 PM
stanz's Avatar
I just found it as well. Thank you. Wow. This is going to be a tough one to replace. Probably wouldn't be so bad if I didn't have A/C. It's buried under the intake and sandwiched between the block and AAV.
Thanks again!
http://personal.utulsa.edu/~nathan-buchanan/93fsm/engine/47descript.pdf
Good luck.
Old Feb 29, 2012 | 07:54 AM
Roy Lowery's Avatar
Hey Stanz,
Do you have the part 3's for the bypass hoses? I live in a very small town and the local dealership is very rude and very expensive... Thanks in advance!
Old Feb 29, 2012 | 08:42 AM
93yota22re's Avatar
If you don't mind I'd be interested in a list of part numbers and a price. I'm about to rebuild my 22re and Toyota hoses would sure be nice.
Old Feb 29, 2012 | 09:34 PM
stanz's Avatar
Sorry I don't have the part numbers anymore. I also think that some of the hoses are different year to year. You can always call any other dealer around the country and ask for pricing and part numbers then simply say you'll get back to them.
I use Broadway Toyota in Portland and they are excellent.
Old Aug 10, 2022 | 06:26 PM
Youngguy_oldtruck's Avatar
New pictures?
Trying to find where this u- shaped coolant line goes. The links seem to be dead for me. The earlier posts talked about it being by the AAV, but what's the aav?
Old Aug 11, 2022 | 08:56 AM
snippits's Avatar
These Gates part numbers fit a 92 22RE. I think they fit 86 too. Installed all mine 5 years ago, and they are still doing fine. Read the comments on what Gates parts numbers you need. My review was from 2017.
The link below is the coolant bypass hose that goes up under the intake Gates 18400.
Amazon Amazon
Old Aug 13, 2022 | 09:38 AM
Jimkola's Avatar
YT Community Team
5 Year Member
This picture may help. I call the valve in question the Idle Air control valve(IACV)
There's a 4" metal pipe that bolts into the back of the timing cover on the passenger side. That hose goes onto that pipe. It is in a pretty miserable location. Even worse if you have AC.
The pipe is visible if you look under the intake near the timing cover. The hose, not so much.
double Dz
Mar 15, 2020 12:32 PM
rattlecanpaint
Feb 10, 2020 10:17 PM
joseph_w65
Apr 12, 2015 11:00 AM
Ptotherez
Mar 9, 2007 10:06 AM
JoKEpLaYeR
Jul 18, 2004 02:42 AM
