89 22re not starting
Old Jan 3, 2012 | 10:02 AM
Jkelley429's Avatar
i went outside this morning and got in my truck to drive to school. When trying to start the truck, every time i turned the key something up front would click and the truck wouldnt start. I thought the battery was dead so i hooked up a charger and it still didnt start. finally after messing with the key for another 10 minutes, it finally turned over and started. i replaced the starter about 4 months ago, so i dont think that is the problem. any ideas?
P.S.- It has done this once before and only does it when very cold (<20 F).
Old Jan 3, 2012 | 10:15 AM
bigwavedv's Avatar
Check to see that the "click" is actually at the starter if you have a second person around. If its clicking under the dash or in a relay box its not the starter, if its on the starter, it is. It will click on the smaller part of the starter...the solenoid where the electrical contacts are located. Super common. If you got the starter anywhere but Toyota, I would not rule out a good chance it failed again.
Old Jan 3, 2012 | 05:55 PM
Jkelley429's Avatar
ill try that if it does it again, but it started just fine the rest of the day (at least 10 times).
Old Jan 3, 2012 | 06:24 PM
fork's Avatar
that's how it was before my starter contacts gave out completely a couple weeks later. $15 replacement from oreilly and 15 minutes of work, hopefully good for another 25 years.
Old Jan 3, 2012 | 06:40 PM
9194yotapu's Avatar
Talking 1994 motor in 91 truck
hello everyone hopein for a little help here? I did a motor swap for a buddy i put a 94 22re motor in a 91 truck didnt take long at all till plugs didnt fit right in the ECU. so transfered wire harness from old 91 motor seemed to work ok the truck started right up but only for few seconds turn key it starts right back up but only a few seconds and so on. I am gettin a little flustered any help would be greatly appreciated. thanks awesome site by the way
Old Jan 3, 2012 | 06:52 PM
sixstringslut's Avatar
Maybe we should re-read the forum rules, it will work for you so much better.
Old Jan 3, 2012 | 06:55 PM
9194yotapu's Avatar
sorry i am not good with computer stuff thank you i will leave
bigjstang
Jun 2, 2025 03:56 PM
Yota.Jay
Jul 23, 2015 08:08 PM
bryan34w
Jul 6, 2015 05:53 PM
colinmil
Jul 6, 2015 04:03 PM
karbin
Jul 5, 2015 11:37 PM
