Are V6 diffs a direct swap for a 4 cylinder?
Old Jan 16, 2012 | 06:01 PM
skoti89's Avatar
Very very curious. I blew the rear diff on my 87 4runner(non turbo). There is a seller 200 miles south of me selling F&R 456 diffs out of a 93 V6. Looking at outside pictures, I can see the difference, aren't they still 8'' ring gear? Will the rear V6 diff bolt into my 4 cylinder housing, and will the axle shafts still go into the diff(same spline count?)
What about the front, if the rear is swappable, I'll need the 456 front to be a direct swap also. Other wise I wont have 4wd for a while.
Old Jan 16, 2012 | 06:05 PM
waskillywabbit's Avatar
http://home.4x4wire.com/erik/diffs/
:wabbit2:
Old Jan 16, 2012 | 06:23 PM
rattlewagon's Avatar
Yes, they are are a direct swap.
Old Jan 16, 2012 | 06:54 PM
Blackulua's Avatar
Easy fit I did a swap with a 4x4 v6 diff on a 2wd 99 4runner
Old Jan 16, 2012 | 07:02 PM
abecedarian's Avatar
Don't forget to match the front ratio to the rear.
Old Jan 21, 2012 | 04:00 PM
skoti89's Avatar
im seriously woried the front diff may be different. this is the picture the seller sent me. .
this is a pic from MC
Trying to look. Are they going to be a direct swap? are the mountings going to be the same? what about the CV axles. will they mount up the same.
any input appreciated, im leaving tomorrow morning to drive the 400-500 miles to get em.
Old Jan 21, 2012 | 04:01 PM
skoti89's Avatar
and yes I know the pic from MC doesnt have the axle tubes on it. does any one have personanl experience with the swap?
Old Jan 21, 2012 | 04:07 PM
MaK92-4RnR's Avatar
the front is no different. the rear will bolt right in.
Old Jan 21, 2012 | 04:08 PM
nightstalker's Avatar
i just put a v6 third in my 4cyl
Old Jan 21, 2012 | 08:44 PM
Blackulua's Avatar
It looks like the ADD type you may have to swap axle tubes from yours and may need a axle on one side from the dealership.I did a swap like this on my 88 IFS and you should be okay for your swap.
Old Jan 21, 2012 | 10:40 PM
kiyobrown's Avatar
Please see gears link in my sig. You can swap axle tubes, or you can bypass the add setup. Also has threads on how to swap the thirds, and you will not have issues swapping them. Direct swap. I have a v6 4.56 rear diff in my 87 4runner.
jerusry
Oct 19, 2015 05:28 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
scottyg486
Jul 19, 2015 05:34 PM
jjrbus
Jul 17, 2015 07:06 AM
jon.r
Jul 11, 2015 03:34 PM
