Removing inner knuckle seal
Old Jun 24, 2022 | 02:29 PM
68jimmy's Avatar
Good day. I'm in the midst of refreshing the front-end of my '89 4Runner and I had a question about removing the inner knuckle to CV/Axle seal? I hope its not as difficult as removing the inner wheel bearing seal which was a PITA! Should I try tapping a flat head screwdriver around the perimeter and see if it moves? Any tips appreciated. On a side note, the seal on the CV which mates to this one, tap it off with a small ball peen hammer? Thank in advance!
donovan
Old Jun 28, 2022 | 05:48 PM
68jimmy's Avatar
Figured it out. Just needed to use different sized flat blade screwdrivers to break the rust and it popped out... And the CV seal just popped off with a few hits from the ball peen, easy peezy... I was hesitant in damaging the existing seals because the newer design are smaller and don't quite look the same. So I wanted to be sure the new seals were going to work before I tore into the existing ones.
d.
dumptruck.thewookie
Mar 11, 2021 04:32 PM
NW-Yota
Feb 24, 2011 02:05 PM
noneckrex
Apr 5, 2010 12:28 PM
chopitrakeit
Sep 19, 2008 08:28 PM
underfoot
Mar 2, 2004 10:03 AM
