Power loss under load
Old May 31, 2022 | 01:25 PM
Jef Free's Avatar
Thank you for replies.
is it possible for my girl to be running as well as she is with the distributor off a tooth. As stated earlier I have it adjusted to the max and that is no where near center of adjustment slot.
I have checked my fuel pressure.
With the regulator vacuums hose removed and attached to front of throttle body I have 40 +or -
And does not change when I increase throttle
Attaching it to the regulator I have 35 and increase to 40 +or - when throttle is increased.
I know it belongs on the regulator but seems to run better removed which is where I have had it.
It drops consistently when shut off too about 22 and hold there for a little bit. Thanks
Old May 31, 2022 | 02:23 PM
scope103's Avatar
You'll get a lot better results if you stick with one thread for one set of problems. https://www.yotatech.com/forums/f116/timing-315592/
ambernwill06
Feb 18, 2015 05:45 PM
Inferno451
Apr 19, 2012 06:37 PM
svtdriven
10
Oct 18, 2005 07:54 AM
Tato97T100
Mar 16, 2005 08:58 AM
