Refrigerant oil
Old Jun 1, 2022 | 11:31 AM
Yotayak's Avatar
Refrigerant oil
Need help confirming type of refrigerant oil for a new Densco 471- 1141 A/C
compressor for a 1990 Toyota truck with the 22r engine.
the instructions for the replacement compressor says to drain the R12 oil out of the unit and replace it with either ND- oil 8 for the reciprocating swashplate type compressor. Or ND - oil 9 for the rotary through vane type compressor. It is a 134a system.
Old Jun 15, 2022 | 04:29 PM
maxvp01's Avatar
If it's R12 put mineral oil
If it's a system that you are changing over from R12 and you are not replacing every component then use Ester Oil
If every AC part that holds refrigerant is brand new (condenser, dryer, compressor, txv, evaporator) then use PAG oil
85SAS
Aug 15, 2016 12:22 PM
hybridspecies
Aug 6, 2016 07:09 PM
metalmadness24
Jul 1, 2015 10:21 AM
donomite49
Aug 19, 2012 05:04 PM
