93 22 re question
Old Dec 21, 2010 | 10:51 AM
getssidetracked's Avatar
93 22 re question
Is there torque specs for the head plate in back of head ?
Old Dec 21, 2010 | 10:54 AM
PismoJoe's Avatar
I torqued them to 15ft/lbs. No leaks or issues. The screw sizes are not the same though, so make sure you put them in the right spots
Old Dec 21, 2010 | 11:12 AM
2 bolts missing I think they are for the water tube brackets in the back Think im correct ?
Old Dec 21, 2010 | 11:21 AM
PismoJoe's Avatar
It sort of depends. If you have an automatic transmission, there's 2 bolts that secure the water pipes. If you have a manual transmission, there's only one bolt that secures the water pipe.
Either way, the water pipe goes over the EGR crossover plate (this is the rear cyl head plate) and the bolts hold both pieces on.
Here's an ATM pic, ripped off from Jerry
Notice that there are 2 bolts for the water pipes
Old Dec 21, 2010 | 11:24 AM
that helps. Thanks alot I should have thought to take pics while I was ripping it apart
lectric80
Aug 11, 2015 12:02 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
