Autozone Duralast transfer case mount or OEM?
Old Dec 23, 2010 | 10:07 AM
Ilovemountains's Avatar
Ive been reading about transfer case mounts and it looks like the aftermarket solid mounts cause high speed vibrations, not what I need on the interstate... Autozone sells a Duralast with a lifetime warranty for $108 and I can get an OEM Toyota for $110, does anyone have any info on the Autozone part??? Do you think its as good as an OEM or would you just stick with a Toyota part?
Old Dec 23, 2010 | 10:11 AM
Sorry, this is for my 88 V6 Automatic 4x4 ext cab pickup My stock mount with almost 200k on it is pretty loose, I can shake the transfer case around by the drive shaft, which is probably why its shifting kind of hard and the shifter is bouncing around when I hit bumps on the wonderful WV back roads!
Old Dec 23, 2010 | 10:12 AM
snobdds's Avatar
For $2 dollars more, I would go with the Toyota part.
Old Dec 23, 2010 | 10:15 AM
Thats what Im thinking but Im wondering if the Duralast part is made by the same OEM MFG.... The only good thing about Autozone parts is the lifetime warranty!
Old Dec 23, 2010 | 10:25 AM
dntsdad's Avatar
that may be the "good thing". The bad thing is they are not close to the quality of a Toyota part. While your lifetime warranty part can be exchanged, I'd rather go with the part that wont leave me stranded in the first place.
This is about as no brainer as it gets.
Old Dec 24, 2010 | 03:13 AM
pruney81's Avatar
yup, get the toyota one, no brainer.
Old Dec 24, 2010 | 04:45 AM
dropzone's Avatar
Fossilized
You are correct about the solid mounts, they cause a lot of vibration, both of mine do.
As mentioned, get the Toyota mount
Old Dec 24, 2010 | 04:56 AM
tim a.'s Avatar
for that price I would go OEM,or you can try rock auto for a better price on the aftermarket.
Old Dec 24, 2010 | 08:01 AM
diablo's Avatar
I got a V6 tranfer case mount that is OEM from schucks/oreilly for my 4cyl. @ $ 76.oo pretty good price.
Old Dec 24, 2010 | 08:35 AM
93YotaGuy's Avatar
Stay away from Duralast parts. I wrote a thread on a starter I had purchased there years ago and ultimately had to replace it 4 times before I got my money back. At the time I wasn't worried because it was a lifetime warranty and I could just keep getting new ones but in the end I wished that I would have originally purchased it from toyota. I will never waste my time/money on a duralast part again. Since then I have had a toyota starter and it has been going strong for about 3 years.
Old Dec 24, 2010 | 11:37 AM
waskillywabbit's Avatar
Get the Toyota OEM mount. The HD mounts are for rockcrawling applications not dd stuff.
:wabbit2:
Old Dec 24, 2010 | 12:02 PM
muddpigg's Avatar
I'm thinking of a solid mount but thats only because I've got dual case with one being 4.7. Even with solid motor mounts (Marlin bolt trick) I get engine turn when playing on the rocks with both cases in low.
Why not look for a used OEM. FYI the mounts are supose to have flex. You should look for signs of seperation, dry rot, rust, ......
Old Dec 24, 2010 | 12:04 PM
Yep. 4.7 gears and dual cases are a whole different story.
:wabbit2:
Old Dec 24, 2010 | 02:51 PM
Question your V6 mount?
:wabbit2:
I hope your V6 mounts are OEM Toyota because I just put an order through to ya!! ~Matt
Chumlee780
Nov 13, 2015 03:18 PM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
yourrealdad
Jul 29, 2015 11:08 AM
tobylab
Diesel Swaps
Jul 17, 2015 06:51 PM
crashburnoveride
Jul 10, 2015 06:39 AM
