No 4WD Light
Old Dec 23, 2010 | 06:56 PM
highway74's Avatar
No 4WD Light
94 PU 4x4 5spd 22RE, 4x4 indicator light does not work, swapped in a new instrument cluster with tach, still doesn't work, any ideas, is there an electrical sender on the transfer case?
Old Dec 23, 2010 | 07:40 PM
muddpigg's Avatar
There's a connector that is on the passenger side of t-case. Check to see if plugged in. Is an sender there too. Mine doesn't work but it is the cluster, to make matters worse I got dual sticks and forget to put it into 4wd.
Old Dec 23, 2010 | 11:14 PM
yotaconvert's Avatar
Hey man check the clutch safety switch to see if it is malfunctioning i Know its weird but happened to me after a 5speed swap the computer thinks you are in neutral and therefor thinks you do not need 4x4
Old Dec 24, 2010 | 08:56 AM
YotaTony's Avatar
I have a 94 4runner and there is a sending unit on the front of the ifs to the right of the diff that had its wires ripped apart when i bought it that was causing the 4x4 idiot light to not come on.
Old Jan 3, 2011 | 12:09 PM
highway74's Avatar
Thanks for the replies guys, been busy with the holidays and forgot I posted this, have to go check out the truck.
Old Jan 3, 2011 | 08:48 PM
gary96360's Avatar
my 4x4 light also doesnt work either. im pretty sure the connector is missing on the diff
Old Jan 3, 2011 | 11:34 PM
dropzone's Avatar
Fossilized
pretty sure yours in at the Transfercase, not the differential
Old Jan 4, 2011 | 07:20 PM
gary96360's Avatar
yeah ive got one at the transfercase but ive heard theres also one by the add actuator. i pulled the dash today and the 4wd light isnt burnt. and i looked today for a connector at the diff which i didnt see. the 4wd works and something clicks when i stick it in 4by
Old Jan 4, 2011 | 07:51 PM
Highlex's Avatar
Listen to this...
My 4wd light did work when I bought my 4runner, so I looked underneath it at the transfer case and sure enough there was something unplugged, neatly zip-tied away though.
It looked like someone unconnected the plug unpurpose, I cut the zip-tie and re-connected the plug to my transfercase.
Then my 4x4 light started working, but my truck wouldn't go into 4x4.
So I unplugged the plug again and then it could go into 4x4 but the light on the dash didn't come on...
Why do you think that happened?
Old Jan 4, 2011 | 09:50 PM
justin_4runner's Avatar
highlex is the light blinking or just going strait on?
mskalmus
May 28, 2017 07:51 AM
adammtb
Jul 27, 2015 11:57 AM
Athansinis
Jul 27, 2015 08:38 AM
ripp96
Jul 25, 2015 02:32 PM
TokyoD23
Jul 12, 2015 06:01 AM
