fuel tank removal
Old Jan 7, 2011 | 03:32 PM
Runner491's Avatar
fuel tank removal
Hello all,
I know this sounds like a horrible thread, but i have a genuine problem here. My fuel pump went out two days ago (yippie!) so i am removing the fuel tank shield and what do ya know? whoever had the fuel tank out last sheared off all the bolts that hold the tank on and then proceeded to WELD, yes weld, the tank back on to the mounting points. All i want to know is how would someone go about removing the tank without damaging it or having a nice explosion in their garage? i have a sawzall, but that would mess the tank up, i have a friend with a torch (but i really dont have the balls to attempt that). I was thinking about just getting a nice large walbro fuel pump and putting it outside the fuel tank. any advice would be extremly helpful, because i am at a loss has to why someone would weld a gas tank on.
Jon H.
Old Jan 7, 2011 | 04:28 PM
shaeff's Avatar
Spot weld drill, maybe? Have any pics of how it was welded in place? That's crazy!
Edit: What are you dropping the tank for? In all honesty, I personally think it's better to remove the bed. That way you can repaint the frame and really inspect it for problems. Pulling the bed is easy, too, providing that the bed bolts aren't on their last legs. You can lift it off with just two average size people.
Old Jan 7, 2011 | 04:44 PM
flg8r22's Avatar
+1 might just be easier to remove the bed for a short term solution?
Old Jan 7, 2011 | 04:50 PM
some drunk guy's Avatar
Drain the gas, fill the tank back up with water, to prevent a bomb from going off Grind the welds and drop the tank, drain the tank, install the new pump. refill. Thats what I would do.
Old Jan 7, 2011 | 05:16 PM
RMA's Avatar
RMA
by his username i think he has a 4runner maybe ..
but yea how about bsome pics of the welds .. just drill them or grind them ..
filling it with water would be playing it super safe , but not really sure you need to do that .
Old Jan 7, 2011 | 05:30 PM
scuba's Avatar
Isn't there a fuel pump access plate on the inside of the 4Runners?
Old Jan 7, 2011 | 05:39 PM
quiggs12's Avatar
Originally Posted by some drunk guy
drain the gas, fill the tank back up with water, to prevent a bomb from going off grind the welds and drop the tank, drain the tank, install the new pump. Refill. Thats what i would do.
agree!
Old Jan 7, 2011 | 05:43 PM
rattlewagon's Avatar
scuba- no access hole on pickups.
If your tanks welded on.. and your bed bolts arnt to rusty...Id go with the take bed off route.
Old Jan 7, 2011 | 05:49 PM
scuba's Avatar
I know this but.....
Old Jan 7, 2011 | 05:59 PM
Sorry, Im retarded. Yes, there is one on runners.
So...what he should do, is find a 4runner body, swap it over then remove the bad pump through the access panel. Problem solved.
EDIT: Just re-read through the thread, I assumed he had a truck...I hope he does have a 4runner. Would make this much easier. Wouldant have to do the body swap. Haha.
Old Jan 7, 2011 | 06:39 PM
scuba's Avatar
You guys are killing me.
Old Jan 7, 2011 | 06:52 PM
Sorry, Im retarded.
I hope runner491 check this thread again before he cuts the tank out and sees the access panel from the back side.
flg8r22's Avatar
yea, im not so bright!
Old Jan 7, 2011 | 06:58 PM
RMA's Avatar
RMA
the access panel is only for the hose and wire connector .. not big enough or in the right spot for the pump.
not like the first gens
Old Jan 7, 2011 | 10:40 PM
Runner491's Avatar
Ha!
Ya I found the access plate, and like noted above, way to small and not in the correct position. I am not use to dropping the tank for pump replacements ( I am an old school BMW/ Volkswagen guy, this is my first Japanese vehicle ever!) I would post some pictures if I had a camera. I think I will try the drill option first, if that fails I'll just wing it and grab the Milwaukee and saw it out. Thanks for helping out a noob guys (at least a Toyota noob, those old German cars are cranky maintenance whores)
Jon H.
Old Jan 7, 2011 | 10:45 PM
Runner491's Avatar
And there are 4 welds, the two in the rear of the tank are about 2" long and the front ones he just made fat tack spots where the bolts go. I bet this guy could burn a pot of water
Old Jan 8, 2011 | 12:57 AM
wyoming9's Avatar
Red face
It would be great to see pictures.
It takes all kinds me I would cut a hole in the floor big enough to get the sucker out then replace it with a access plate for the future.
Do yourself a favor go to Harbor Freight buy one of the cheap grinders and some cut off zip discs make the job much easier then a saws all
Old Jan 8, 2011 | 06:12 AM
skypilot's Avatar
WoW! What a blast!
I would cut a hole in the floor first. then make a cover plate up and screw down with some self tapping screws.
Grinders & vaporized gasoline is just he ticket for a heavenly trip.
Old Jan 8, 2011 | 11:56 AM
Runner491's Avatar
Alright, so i started work on it around 9am (neighbors were thrilled to hear my compressor fire up ) instead of cutting the tank off i just buzzed a hole underneath the seat big enough to get the fuel pump out. removed the old pump and tried to test it, ran 12v power directly to it, it actually just got really hot! DANGEROUS! slapped the new one in there, put the assembly back in the tank, siliconed the daylights out of the hole i made in the floor and bam! i have a running runner again! yay thanks for the tips guys. I do not know why toyota did not put a panel there in the first place, would be so much easier to replace the pump.
Old Jan 9, 2011 | 01:26 AM
wyoming9's Avatar
Red face
I guess some people are just to dumb to be scared of fire and explosions..I get scared driving in New Jersey
Glad you got it up and running.
In my book a lot easier then dropping the tank
Eggslinger
Jun 8, 2019 03:32 PM
Doug4320
Mar 24, 2018 10:11 PM
skoti89
Sep 11, 2015 07:46 AM
pyramid
Jul 30, 2015 10:05 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
