Temp Sensors
Old Dec 31, 2010 | 01:33 AM
rocklover's Avatar
Question Temp Sensors
Weird question. I know there are two differen't sensors but which is which. I thought the sensor on top, right next to the thermo housing is for the gauge in the cluster and the one on the front of the engine is for the ecu. So I unplugged and installed an aftermarket gauge on the top one. You may be wondering what the hell my question is well... My gauge in the cluster still works! so i thought it was just stuck, nope. My engine started overheating and the gauge in my cluster went up right along with my aftermarket gauge???
Can someone help me out here? It was my understanding the top unit was for the gauge, front by fuel rail for ecu. How the hell is the cluster temp gauge still working??? It is not plugged in....
Old Dec 31, 2010 | 04:45 PM
rocklover's Avatar
Did some research and found this thread, this is the sensor i was talking about
https://www.yotatech.com/forums/f116...olcano-209020/
From the details in the thread it sounds like it is for the ac unit. Can anyone else confirm this?
This leads me to believe that the temp sensor on the front of the engine is for the gauge in the cluster and the ecu? which brings me to my next question.
That gauge always sits halfway and never drops no matter how cold it is when i start the engine, but, if it heats up or overheats it does go up. what the hell is going on here. Could it possibly be sending wrong signals to the ecu too? and causing it to keep in open mode?
Old Dec 31, 2010 | 08:04 PM
barrel roll's Avatar
above the thermostat is for the AC
green under the throttle body is for the ecu
black under the throttle body is for cold start timing?
on intake manifold, aft of the thermostat and forward of the egr is for the gauges
Now if I could only find part numbers...
Old Jan 1, 2011 | 03:24 AM
mldave's Avatar
on my 86 22RE..cold start injector time switch is black on left..green on right is temp sensor.This located under t-stat housing.
Old Jan 1, 2011 | 09:20 AM
4runnerx3's Avatar
That green temp sensor is for the ECU for engine temp for air/fuel ratio.
jmoua
Mar 29, 2023 03:42 PM
TACOJO
Nov 27, 2015 05:26 PM
rjtrials
Aug 6, 2015 07:25 PM
bighaydn
Aug 4, 2015 07:17 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
