Brake bleeding - Drips out of bleeders
Old Jan 2, 2011 | 11:41 PM
91Toyota's Avatar
I just replaced the brake line to the rear brakes. I got everything going and needed to bleed the brakes. I started with the PR and started bleeding and it drips out. I did the DR and still dripped out. I then tried bleeding the LSPV and bled just fine and shot out. I tried bleeding the back brakes again and still just drip out. The brake pedal gets tight but i'm worried they aren't bled. So, what do I do? It could be the LSPV is shot, the line to the junction block is clogged, the junction block is clogged/shot) Its either of those three things. Unless the bleeders were both clogged themselves? (they had the rubber caps on them) What do you suggest i do?
Thanks, Trevor
Old Jan 2, 2011 | 11:53 PM
psfpilot's Avatar
Is it possible that there is so much air in the system back there that you aren't getting good flow yet?
Old Jan 3, 2011 | 07:25 AM
InvaderTrax's Avatar
You're doing this with the wheels on the ground or jack stands under the rear axle, correct? Maybe you should have someone pumping the brakes while you work the bleeders
Old Jan 3, 2011 | 08:09 AM
Junkers88's Avatar
When I did mine last time the rears just dripped also. I pulled the bleeders and cleaned them with a tooth pick and hot water, they were just packed full of road dirt and stuff.
Old Jan 3, 2011 | 09:25 AM
JonnyBoy's Avatar
I would try Junkers idea, just try to clean the bleeders, or get new ones, cause that's cheapest. However, the LSPV is still a possibility. Mine was rusted and not flowing on my '83, and it's been a SoCal truck it's whole life, so I know up there in lovely Salem some rust could develop.
It's a lil messy, but you could also try pumping the brakes once without any bleeder in place and see what kind of flow there is. Could rule out the LSPV and the junction block for just the cost of some brake fluid.
Blamalam
Mar 12, 2022 07:34 AM
Colington
Mar 8, 2020 09:51 AM
87toy pickup
Sep 7, 2015 06:42 PM
agrout
Aug 13, 2015 06:12 PM
CanRunner
Jul 20, 2015 01:29 PM
