Engine Heaters..... What do you think?
Old Dec 22, 2010 | 04:25 PM
motocaveman's Avatar
When the temp regularly drops well below freezing, how many of you use an engine heater and/or battery heater? (oil pan heating pad, block heater, etc...). If so, what are your suggestions on selecting one?
Old Dec 22, 2010 | 07:54 PM
RobD's Avatar
If you're dipping just around freezing (32F or 0C) a block heater is more than enough.
Dip to 14 to -4 F (-10 to -20 C) and a battery blanket will help. At that point, your battery can lose up to 50% of its cranking power.
Below -4 F (-20 C) and the oil pan heater is nice to have, but I wouldn't worry unless you actually get below -22 F (-30 C). Using a good synthetic oil will help, too.
Old Dec 22, 2010 | 08:00 PM
matstaley's Avatar
I use a magnetic oil pan heater. It works great and the engine cranks over a lot easier when its stupid cold outside. It was only around 50 bucks at Carquest.
Old Dec 22, 2010 | 09:03 PM
We don't get that cold here very often. When it does, I know it's a PIA to get this thing to fire up!
Old Dec 22, 2010 | 09:21 PM
dropzone's Avatar
Fossilized
just be sure to unplug them when you go to take off. Spent a few years in alaska watching newbs back up and ripping their extension cords/grills off the front of their cars/trucks..gave up waving at them because they would never stop
Old Dec 22, 2010 | 09:28 PM
wyoming9's Avatar
Red face
I have used these on and off for at least 40 years.
Of all the block type heaters there seems to be for the most 2 kinds the kind you plug in with engine warm and it holds the temp.
The other kind you plug in very cold engine 1/2 hour 45 minutes depending on engine size you are ready to crank it over.
*** Very important with coolant type heaters unplug before cranking you hit a air pocket the heating element is cooked.
get a better product There are the kind you install by removing a freeze out plug. Others area Tank type that go in the radiator hose.
I have used the magnet oil pan heaters a pain to crawl under unless you mount it . it is exposed to all the road slop..
I have used the dip stick heaters I don`t know if they are still around or not. Again pulling it out and installing the dipstick
No Matter they do save a lot of wear on the starting system
icentropy
Sep 16, 2020 02:47 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
jasonty
41
Dec 23, 2018 01:00 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
