Wheel problem. Help.
Old Dec 5, 2008 | 01:25 PM
Cwaters1184's Avatar
so when i bought my truck, the guy i bought it from gave me a set of 16in wheels. Last week i mounted the tires to them, and i go to put them on today and the backs mounted up find, but i have a problem in the front, the wheels wont fit over the manual hubs all the way. It'll slide about 2inches on then it hits a wider part of the hub. Any simple fix for this like a set of wheel spacers? i mean i the wheels have a 1/4in lip that looks like i could have machined out they should fit then, but that would obviously be alot more expensive. Thoughts?
Pic of Wheels:
http://img.photobucket.com/albums/v1...Picture043.jpg
Old Dec 5, 2008 | 01:53 PM
mrmatson's Avatar
Old Dec 5, 2008 | 01:57 PM
deines97runnah's Avatar
Have them milled.
Old Dec 5, 2008 | 03:00 PM
DeathCougar's Avatar
The only way to make it work is to have them milled. The amount of wheel spacer you would need would put too much stress on the bearings.
Old Dec 5, 2008 | 03:05 PM
abecedarian's Avatar
unless the wheels have huge backspacing, spacers won't help: like DC said the size of spacer you'd need would put too much stress on the wheel bearings.
boring out (milling) the center is the only solution. the wheels have plenty of clearance between the center and the lugs so as long as it's done right, shouldn't cause a problem.
Old Dec 5, 2008 | 06:56 PM
thanks. I guess any decent machine shop should beable to mill them?
Old Dec 19, 2008 | 09:32 AM
took my wheels to a machine shop. got them back today.. they look good, not like they came from teh factory, but theres no adverse effect of the machining. Wheels now fit over my hubs. Yay! now i can go have my tires put BACK on and get this beast rolling again.
glowz825
Jan 25, 2022 09:28 AM
PlayAwhile
Jul 20, 2015 11:36 AM
rushw
Jul 18, 2015 01:46 PM
bryan34w
Jul 6, 2015 05:53 PM
colinmil
Jul 6, 2015 04:03 PM
