getting out of 4wd
Old Dec 3, 2008 | 03:06 PM
DupermanDave's Avatar
getting out of 4wd
I tested out 4wd today in the icey conditions. After I got on roads that weren't slick and icey, I tried to take it out of 4wd. I couldnt get it out. I moved and jiggled the stick around as much as I could and couldn't find my way out of 4wd. I unlocked the hubs and put it in 4wd high I think, and it popped and I was able to remove it from 4wd and put it in the neutral position.
I dont know what did it, but is there a way or a trick you guys know to remove the 4wd easier than this?
Old Dec 3, 2008 | 03:20 PM
toyota4x4907's Avatar
were you stopped when you tried to take it out of 4wd? Sometimes mine doesnt like to pop out unless Im rolling forward, or driving under 55mph. ( you shouldn't shift into or out of 4wd over 55mph.) if you were driving, try pushing in the clutch and taking it out of gear then do the t-case lever.
Old Dec 3, 2008 | 03:28 PM
I was stopped. I wasn't sure if it was safe to engage and disengage 4wd when the truck was rolling. Is it safe?
I was stopped when I took it out of gear and I did have the clutch in. I was rolling forward when it popped. After the pop I stopped immediately to make sure everything was okay and tried removing the 4wd again. THe pop made it so I can disengage the 4wd.
Old Dec 3, 2008 | 03:31 PM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Next time, drive in reverse a few feet. Everything will disengage and you'll be able to put back into 2 hi. Learned that trick in my 1st toy 4x4.....an '84
Old Dec 3, 2008 | 03:38 PM
Yes it should be safe. I've always engaged and disengaged the 4wd at speeds up to 55mph with no ill effects thus far. You have manual locking hubs correct? If you have the Auto hubs ( not ADD) then you need to do what a4runnerfreak said and go into reverse a little.
Old Dec 3, 2008 | 03:39 PM
jason191918's Avatar
Read your manual or visor. Mine says I can go between 2hi and 4hi as long as i am under 55. I too have to move it a lil bit to engage/disengage it.
Old Dec 3, 2008 | 03:48 PM
Matt16's Avatar
You got it, the driveline was a little bound up. Sometimes if my t case wants to stay in 4wd, i bounce the gas a little. The combo of engine braking and acceleration has always worked.
Old Dec 3, 2008 | 03:49 PM
4Crawler's Avatar
I almost always swtich 2H-4H and back in motion. Best to be moving straight ahead (or back) and don't be accelerating or decelerating. Then just ease off the gas pedal and push the lever into 2H and it should pop right into gear. Problem is the drivetrain can bind up if you are in 4WD and making turns, or if you had one or more tires spinning, etc. The wheels all travel different speeds and that makes the gear or chain driven transfer case get bound up.
Old Dec 3, 2008 | 04:20 PM
just a 22re's Avatar
well with both my runners i leave the hubs locked and do about 75-80 and push the clutch and let her down into 4wd on the fly at 80mph and when it gets dry again i just clutch and back into 2wd at 80 mph but thats just me i guess lol
Old Dec 3, 2008 | 04:40 PM
And thats why wifee don't like you, Norbert.........
Old Dec 3, 2008 | 04:47 PM
it never grinned or was hard to shift or anything
kawazx636
Oct 6, 2021 03:03 PM
Daenerysdad
Oct 1, 2015 07:33 PM
tylermx71
Sep 29, 2015 08:49 PM
Cycles
Sep 29, 2015 06:37 AM
May-39
Sep 6, 2015 01:05 PM
