Headgasket job coming up...
Old Nov 30, 2008 | 02:37 PM
87LVRunner's Avatar
Well I have coolant leaking out between the block and the head above the drain plug on the drivers side. Truck runs like a top, oil is completely clean. So, besides new gaskets and surfacing the head, what else should I do? Should I do an RV cam at the same time? Should I just get a new complete head? I did the timing chain, but should I do it again? I'm going to get some dye to confirm the leak first. It couldn't be as easy as retorquing the head bolts could it?
Old Nov 30, 2008 | 03:33 PM
annoyingrob's Avatar
Are you sure one of the frost plugs hasn't rusted through? I've seen it happen.
If you're going to be doing the head gasket, might as well do a cam at the same time. (that's what I did ). New timing chain and guides is a good idea too.
kgcwb44
Jan 29, 2023 10:02 AM
icentropy
Sep 16, 2020 02:47 PM
jasonty
41
Dec 23, 2018 01:00 PM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
