injectors
Old Dec 2, 2008 | 12:56 AM
frm_808's Avatar
injectors
i own an 87 22ret and my injectors are starting to go out..wheres the best cheap place to get a set? local parts store,or does someone know a place online. this is pretty much a daily ride for me and no need to get bigger injectors
Old Dec 2, 2008 | 06:16 AM
Flash319's Avatar
Why do you think you need injectors?
Old Dec 2, 2008 | 10:44 AM
space-junk's Avatar
witchhunter, i hear, does good work...
they are reviewed here...
https://www.yotatech.com/forums/f105...eaning-159750/
Old Dec 2, 2008 | 04:49 PM
frm_808's Avatar
normal driving i run a normal a/f mixture. under boost flat out lean.....injectors are needed
cool thanks man, prolly will be doing this if i cant find a decent set
Old Dec 2, 2008 | 05:50 PM
abecedarian's Avatar
if the tps is malfunctioning or needing adjustment it can cause the fuel mix to lean out around 3000 or so rpms.
Old Dec 2, 2008 | 06:04 PM
whorider's Avatar
Is your fuel pressure up to par? Is it a ported turbo, bigger, or stock? Have you tried a piggyback controller like the APEXI afc neo? Pretty sweet and easy to tune. How lean is it going? Past 17 to 1. Only problem with afc is a wide band is needed.
Old Dec 10, 2008 | 09:46 PM
frm_808's Avatar
well like itll be fine around there ill slowly bring up the rpms and itll run fine all the way up. but if i actually get on it once it hits boost craps on its face and leans out
im pretty sure my FP is up to par. dont have a gauge to actually hook it up to. the turbo is stock and rebuilt last year by previous owner. ive played around with one of those on my 240 but never actually thought it could be hooked up to my truck....? i jus have a dumb gauge for the a/f ratio its not a wide band. just wanted to make sure everything was runin up to par when i got the truck
Old Dec 11, 2008 | 07:08 AM
mxridercrf450r's Avatar
Ive had two sets cleaned by witchhunter. Quick turn around, relatively inexpensive and quality service.
moparbay
Oct 6, 2015 09:24 AM
bradahman
Oct 1, 2015 09:24 AM
themightykhoner
Sep 18, 2015 02:28 AM
larrys93pickup
Sep 17, 2015 07:05 PM
Kytowboater
Sep 17, 2015 11:17 AM
