1990 toyota 4runner engine swap
Old 04-20-2014, 02:54 PM
Efrain90's Avatar
Hey guys. I have a rig with a blown head gasket and I'm pretty sure a blowed exhaust valve as well. Many people told me to put a napkin on the end of the tail pipe to see if it sucks in air. It did indeed suck the napkin at times. So bear with me. I need opinions on what I should do. Should I keep riding it till the engine blows and swap the engine? Or change the valve and gasket? Also, can a v8 fit in there? Like with the same tranny as the v6? It's a 4x4 auto tranny. Thanks!
Old 04-20-2014, 03:14 PM
JasonYota's Avatar
Depends on your budget and/or mechanical ability.
Old 04-20-2014, 03:53 PM
Efrain90's Avatar
Well I mean I just want opinions and I can go from there. Doesn't matter like budget wise. I can spend a lot or a little. And I only know little about mechanical so bear with me please
Old 04-20-2014, 04:00 PM
JasonYota's Avatar
Well you can
A. Rebuild/fix the 3.0 you currently have.
B. Swap in a 5vz and swap to a manual trans.
C. Swap in a 5vz with a newer auto trans with a gear driven transfer case.
D. Swap in a Toyota V8.
E. Swap in a diesel.
Options are endless with no budget just depends what you want and how you use the vehicle.
Old 04-20-2014, 04:07 PM
Efrain90's Avatar
Well you can
Okay thanks. You know around how much it is for a 5vz with auto tranny? Or can I just get a 3.4 and just drop it in with the auto tranny of the 3.0? I'm not thinking on rebuilding mine as it leaks oil like hell from many, many sides.
Old 04-20-2014, 04:22 PM
JasonYota's Avatar
Price will depend on if you do it your self or pay someone. I have about 1k in my 1st 5vz swap(manual trans). That is doing all the work myself. I am about to start a 5vz with auto trans swap when funds start rolling in.
Old 04-20-2014, 04:24 PM
Efrain90's Avatar
Oh alright I see. But will the 3.4 fit on my tranny? My engine currently is a 3.0 auto tranny
Old 04-20-2014, 04:38 PM
JasonYota's Avatar
Yes, but I would swap to a newer trans while your swapping the 3.4 in. Might even be easier with the wiring part of it going with the auto originally behind the 3.4.
Old 04-20-2014, 04:42 PM
Efrain90's Avatar
Hmmm. Alright because the tranny I got is semi new. I assume it will need an ecu as well? Or does it come with the engine? See this is the thing. I'm in Lafayette Indiana and can't figure out a place that has an engine for my truck. You know a website that can tell me the nearest place so I can get an engine? That would really help me a lot if you don't mind.
Old 04-20-2014, 04:51 PM
JasonYota's Avatar
Look in salvage yards, craigslist. Other places for a rebuilt engine you might not find local but the could ship to you.
Old 04-20-2014, 04:52 PM
Efrain90's Avatar
Oh alright got ya. Thanks will be checking some salvage yards around me
Old 04-21-2014, 10:58 AM
Efrain90's Avatar
I also got wondering. If I don't really drive highways or pull anything can I just be fine by rebuilding the engine? Cause of what I hear people say they get the 3.4 to haul more things easier.
Goddamnboh
3.4 Swaps
12
05-11-2016 09:22 PM
vasinvictor
01-20-2016 12:39 PM
Alex Bessinger
06-28-2015 10:05 AM
GorgeRunner
06-27-2015 07:01 AM
Quick Reply: 1990 toyota 4runner engine swap
