Rear Lock-Right & Carrier Question
Old May 5, 2014 | 05:16 AM
UteRunner's Avatar
Been searching at length for an answer to this but to no avail.
I bought a used Lock-Right locker that is still installed in the carrier. Can I keep it in there and simply swap the ring gear or should I swap it over to the carrier in my 4Runner? Does vehicle specific wear-and-tear come into play here?
Old May 5, 2014 | 07:18 AM
Rerunn's Avatar
As long as the Carriers are the same you can swap the ring gear over. Like if the lock right carrier is a 4cyl carrier and your 4runner is a 4cyl carrier you should be good. If not you'll have to do some converting
Old May 5, 2014 | 07:26 AM
UteRunner's Avatar
Thanks, and yes, they are both 4cyl. Should have mentioned that.
Old May 5, 2014 | 09:31 AM
Rerunn's Avatar
OK cool should have no problem then just get a set up kit and set it up and go!
Old May 5, 2014 | 10:30 AM
UteRunner's Avatar
You mean a ring and pinion set-up kit? From the info I've found, no gear set-up is required for a Lock Right install.
Old May 5, 2014 | 10:40 AM
millball's Avatar
If your original open diff is in good shape, you should just swap the lock-Right into your existing carrier.
If you swap your ring gear onto the carrier that the locker is presently installed in, there could potentially be gear set-up problems that could require re-shimming or other adjustments/parts.
Old May 5, 2014 | 12:16 PM
Cyberman's Avatar
x2
just move the lock-right over to your carrier.
There isn't much to taking it out of one and putting it in yours.
Old May 5, 2014 | 12:57 PM
dropzone's Avatar
Fossilized
If the R&P is the same why not just swap thirds?
Old May 5, 2014 | 02:05 PM
Cyberman's Avatar
Op didn't say he had the whole third, or same gear ratio.
Old May 5, 2014 | 05:57 PM
Rerunn's Avatar
Yes a ring and pinion set up kit....
the1998sr5
15
Jul 14, 2020 08:35 PM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
