My first Toyota and I need help.
Old May 1, 2014 | 02:05 PM
erav82's Avatar
Question My first Toyota and I need help.
Hey any/every one. I am trying to pull a 22re out of my '95 4x4. The problem is I've got everything undone, well at least I think I do, but the intake side of the bell housing doesnt want to seperate. The bell on the ehaust side is cooperating. Does the starter need to be pulled?
Old May 1, 2014 | 02:15 PM
toyota4x4907's Avatar
Yes. It does.
Old May 1, 2014 | 03:01 PM
yotayes88's Avatar
Yes the starter needs pulled and also check for any "hidden" bolts .
Old May 1, 2014 | 04:13 PM
thefishguy77's Avatar
The top bolt of the starter is easier to get from the front of the truck with long extensions. Btw. Disconnect the slave as well. Not sure if you pulling the block or the wiring harness as well. If the harness is coming with unhook the O2sensor and 2-3 plugs on the tranny/t-case.
Old May 1, 2014 | 06:10 PM
erav82's Avatar
Thanks guys. Once I pulled the starter and the one hidden bolt everything separated nicely.[/IMG]
Charecter1
Nov 6, 2023 10:08 AM
Yota.Jay
Jul 23, 2015 08:08 PM
redneck17
Jul 17, 2015 07:44 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
bryan34w
Jul 6, 2015 05:53 PM
