I need electrical help
Old Apr 26, 2014 | 03:47 PM
cpljenkins01's Avatar
I have a 1990 pickup I am having some problems. I noticed the day I got the truck a year ago that everytime I turn the blinker on left and right. It makes my volt meter bounce so to me its pulling a good bit of current. I put leds in the rear and it still bounces but just a little faster. My problem now it that I can still turn my passenger side blinker on and it works. But my driver side when I turn it on it draws a lot of power and kicks a fuse after 4 blinks so I know there is a ground problem but also woundering if it way be in the switch? Has anyone else had this problem?
Old Apr 26, 2014 | 08:48 PM
abecedarian's Avatar
It's possible that it's the combination switch contacts causing issues. When they wear, it can increase resistance (electrical) and cause excessive amperage draw. That does not mean there isn't an issue elsewhere though.
I would suggest checking the bulb housings and connectors, making sure they are clean of any corrosion before jumping off elsewhere.
Old Apr 27, 2014 | 04:47 AM
I checked the wires that run down the frame on the passenger side and its not getting any power.
Old Apr 27, 2014 | 02:46 PM
Its fixed. The wire plug under the passenger seat was melted a little
Old Apr 27, 2014 | 02:58 PM
rworegon's Avatar
What caused it to melt?
Old Apr 27, 2014 | 03:10 PM
The plug had corrosion in it so I cleaned it out and greased it
Obmi
Oct 4, 2015 11:30 AM
voiddweller
Sep 28, 2015 11:21 PM
Project90
Sep 24, 2015 11:40 PM
Boomer8404
Sep 24, 2015 01:12 PM
xzen73x
Sep 14, 2015 03:00 AM
