'91 v6 4runner electrical gremlin
Old Sep 11, 2015 | 09:43 PM
xzen73x's Avatar
I'm having issues with electrical on my 4runner. It started earlier this week. I went to start my truck after work, I lost all power when I turned the key to start it. After shutting it off and turning back on, it started again and all was well.
Today I can't start it at all. Turning headlights on results in a loss of any electricals anywhere in the vehicle. I have power and dash lights with the key "on" until I either go to crank it or turn headlights on, after which it instantly loses power again.
With the key on, I have full power to the windows, brake lights, interior lights, and horn. I've tried a different battery as well so I know that isn't the issue.
Does this sound like a shorted wire or a bad ground? I have very poor knowledge of electrical, no idea where to start here
Old Sep 12, 2015 | 12:35 AM
wyoming9's Avatar
Red face
It sounds like you need to get up to speed on simple DC circuits
A Multimeter is your friend .
Without real voltage numbers your just guessing
Always start at the source of power .
Battery voltage at least 12 vdc or slightly higher with the engine off.
Terminals clean and tight not broken .
Does not hurt to pull the grounds off and clean the lugs and the attaching hardware .
Shorts are a direct path to ground will cause circuit protection to open or a melted wire till it melts enough to open.
A fire if anything flammable is close enough.
Old Sep 14, 2015 | 03:00 AM
AKHeathen's Avatar
still sounds like a battery connection, likely to the main engine fuse block by the battery. i would start by cleaning the battery connections up.
sandyota
Feb 4, 2021 11:16 AM
coryc85
Sep 9, 2015 06:24 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
Poncho0206
Jul 10, 2015 06:21 PM
AaronM
Jul 8, 2015 07:15 PM
