What is the purpose of a rocker arm spring?
Old Apr 20, 2020 | 06:58 PM
Jakez's Avatar
Searched all over Google and cannot find anything explaining these, not even the patent for them >.<
Old Apr 20, 2020 | 08:18 PM
millball's Avatar
Don't overthink this. The springs are required to keep the rocker arms pushed over in proper alignment with the cam lobes.
It would be possible to dispense with the springs by using shim collars, but more costly.
Old Apr 21, 2020 | 10:57 PM
Jakez's Avatar
Just seems odd and risky to use them and allow the "possibility" of the rocker arms sliding sideways and hitting each other, especially if there is never a point where the sideways movement is utilized.. why not just have them in fixed positions..? But maybe you're right and I'm just overthinking it lol.. I guess I could see why they would want to save on unnecessary iron(?) usage and weight..
Old Apr 23, 2020 | 01:49 PM
Co_94_PU's Avatar
Replacing tappets and inspecting your cam?
Old Apr 23, 2020 | 02:24 PM
Jakez's Avatar
Is that the screw you use to adjust the valves, or the flat piece of the rocker arm that rides on the cam? Either way still don't think the risk is necessary to do such things..
Old Apr 23, 2020 | 02:29 PM
Co_94_PU's Avatar
Trust the physics, there are no lateral forces it's cycling up and down.
glitchinq
Sep 19, 2017 07:33 PM
GodwinAustin
Aug 22, 2016 02:14 PM
4x4toypu
Oct 24, 2009 08:15 AM
racingcameron66
9
Dec 3, 2007 10:18 AM
darth brian
Jun 17, 2006 02:50 PM
