4runner runs rough
Old May 18, 2020 | 01:22 PM
Budlite89's Avatar
4runner runs rough
I have a 91 4runner 3.0 automatic that will not run without the accelerator floored. I have replaced plugs wires and distributor. Also have replaced the mass air flow sensor, fuel pump and filter as well as several vacuum lines. The air intake is new as well. Cannot get it to start without the pushing the gas and no check engine lights are on. When it does start the MAF sensor makes a popping sound and as soon as you let off the gas it dies. Any ideas? Thanks
Old May 18, 2020 | 06:19 PM
scope103's Avatar
Welcome to YotaTech. I'd start by checking the ignition timing. Have you done anything (before it ran rough) that could change the valve timing?
Just so you know, you don't have a mass air flow sensor. You have a volume air flow sensor. Different technologies. Just call it an AFM and you'll always be right.
2Whlin
Oct 14, 2015 10:58 AM
bill_collector
Mar 8, 2011 11:27 AM
Matt96Tacoma
Feb 5, 2010 10:36 AM
DupermanDave
Nov 26, 2008 07:02 PM
mindaugas
Feb 2, 2008 04:19 PM
