Thick oil buildup
Old May 10, 2020 | 07:02 PM
JoshToy84's Avatar
Thick oil buildup
This might be no brainer question but I just want to be sure.
Ive got some pretty thick oil buildup on the front of my engine I want to clean off, and I was wondering, what's the best way to collect and dispose of the gobs of oil I'm expecting to clear off this motor?
Collect in a pan and take to an oil disposal center?
Old May 10, 2020 | 08:57 PM
Co_94_PU's Avatar
The places taking in "used oil" are sending it for recycling/ rerefining the sludge on the outside of your engine is trash. Spray it off with a solvent. Evaporate the solvent and dispose of it..
If you cared to go thru the trouble something like draino will convert it to "soap" which is slightly more landfill friendly.
Old May 12, 2020 | 09:59 AM
atxMatt's Avatar
If you can get to a coin operated car wash, you can do it there. Typically they have a grease and grit trap and are setup to recycle the sludge that comes off from car washing. I'd take a good degreaser, spray it down, let it soak then throw in a few quarters and blast it of. Wash rinse repeat.
Old May 12, 2020 | 10:21 AM
JoshToy84's Avatar
I'm a little skeptical about spraying water around electrical components like the alternator, starter..also you never know if a plug isn't seated right...water seeps in..overspray gets into the coil...
Old May 12, 2020 | 10:39 AM
5 Fists's Avatar
This has also been my concern with doing something along these lines, but I know a lot of guys will wash engine bays down like this.
Anyone that has done this chime in? What's common practice, bring some poly and cover electrical before spraying down?
Old May 12, 2020 | 10:59 AM
JoshToy84's Avatar
I can tell you I've seen a few you tibe vids that would suggest NOT hosing down the motor itself. If cleaning the bay you can, just cover the motor.
Old May 12, 2020 | 01:29 PM
JoshToy84's Avatar
Well considering there wasn't much room to really clean the front, and not wanting to disconnect too much, I didn't do too bad of a job.
Old May 12, 2020 | 04:47 PM
atxMatt's Avatar
Well see, top of the engine I would never spray, too many vac lines and electric, but you asked about the front of the engine. As long as you are not spraying at full pressure (and risk getting past any seals (same goes for suspension and steering parts), spraying the side/front of an engine should be no big deal. Top, never. Top of an engine I just mist with cleaner then wipe it down with disposable rags. As for disposal of oil rags, most oil recycling places won't take them. If you really want, you can save them for a community household hazardous waste disposal event (or some city recycling centers will take HHW all the time). Me, I usually just double bag them and throw them away. It won't be the worst thing going into the landfill.
shafner30
Jun 9, 2017 12:10 AM
laxlan
13
Aug 22, 2013 08:57 AM
FuelforWar
Dec 26, 2011 11:14 AM
nermalgod
9
Mar 24, 2006 12:00 PM
darth brian
Jan 19, 2006 10:31 PM
