Auto to 5spd swap help!
Old May 5, 2020 | 04:32 PM
808-3VZE's Avatar
Have a 91 4runner 3.0 4x4 automatic transmission. I have the 5spd 4x4 transmission with transfer case can I use the driveshaft from my automatic transmission or do I need the 5pd one? Thanks in advance!
Old May 5, 2020 | 04:42 PM
Co_94_PU's Avatar
Easy enough to measure the length of the transmission and transfer cases..
Sort answer no not going to work from what I recall, you need the manual gear box, drive shafts and the transmission cross-member that match the transmission assembly you're installing.
But by all means go measure rather than take the word of someing on the internet.
Old May 6, 2020 | 04:43 PM
MrSUT's Avatar
Did this same swap. use the manual drive shaft and trans mounting bracket. all will bolt right up no problems.
2010nctaco
3.4 Swaps
18
Apr 12, 2015 06:14 PM
kooltacos
3.4 Swaps
Jun 7, 2010 10:25 AM
mfxsupervillain
May 6, 2010 01:57 PM
91Toyota
Dec 4, 2008 02:39 PM
