Need a valve (I think) ID'd
Old Apr 24, 2020 | 10:27 PM
JoshToy84's Avatar
This would be the valve that is on top of the valve cover, hose connected, closer to the front of the engine. To my understanding the PCV valve is closer to the back of the motor on the valve cover.
Old Apr 25, 2020 | 05:23 PM
JoshToy84's Avatar
Anybody?
Old Apr 25, 2020 | 06:03 PM
scope103's Avatar
A picture is worth a thousand words. You've got about 960 to go. Get on it!
Old Apr 25, 2020 | 06:32 PM
JoshToy84's Avatar
Sorry was lazy and trying to find a pic online instead of just taking one. Right up above the Y:
Old Apr 25, 2020 | 07:07 PM
Co_94_PU's Avatar
No valve there just the other end of the PCV system..
What made you think you needed this "new valve"?
Old Apr 25, 2020 | 08:20 PM
JoshToy84's Avatar
There appears to be some oil leakage from there. Maybe I just need to replace the hose.
Old Apr 26, 2020 | 08:23 AM
Co_94_PU's Avatar
Get it clean and dry before you decide what is leaking.. You might need new grommets for the valve cover, you might need a new breather hose, you might need both.
Old Apr 26, 2020 | 11:02 AM
2ToyGuy's Avatar
I've replaced that hose once. Not bad for 30+ years
The original hose clamp that was on it kept getting weaker, and the oil leak kept increasing, so when I replaced the hose 2 years ago, I put a screw down hose clamp on it, and it's been leak-less (is that a word??) ever since. One of those hose clamps that are in the thousands at every auto parts or hardware store.
One thing that helps, I found, was to ensure the riser the hose fits down onto is good and clean. Much dirt, or whatever on it, and it will leak. When it's nice and clean, and so is the inside of the hose, the rubber seals down nice and tight, and it doesn't leak. Any time I take the hose off to set the valves, replace the thermostat, whatever, I wipe the riser and inside of the hose with a rag with a little carb cleaner on it, and it seals up for a treat.
Good fortune to you!
Pat☺
Old Apr 26, 2020 | 11:09 AM
JoshToy84's Avatar
Pat☺
Thanks! What is the official name for that hose so I can get one?
Old Apr 26, 2020 | 11:36 AM
Paul22RE's Avatar
5 Year Member
Your grommet appears to be cracked and possibly the cause of the leak, but here is the hose you are asking about:
12263 HOSE, VENTILATION, NO.3
PART # 12262-35060
Old Apr 26, 2020 | 11:39 AM
JoshToy84's Avatar
Is the grommet something easily replaced or will I have to remove the valve cover to replace it?
Old Apr 26, 2020 | 12:23 PM
scope103's Avatar
Originally Posted by Paul22RE
... 12263 HOSE, VENTILATION, NO.3
PART # 12262-35060 ...
Just when I thought ordering Toyota parts couldn't get any more confusing!
At first I thought you mixed up the two hoses. But I, too, get hose 12263 as having part number 12262-35060. https://parts.lakelandtoyota.com/sho...roduct=3928331
I would be doubly careful ordering this part. I'd make sure the counter-woman knows about this weirdness. If I got the wrong part, I'd like something to point the finger away from me.
Old Apr 26, 2020 | 01:07 PM
Paul22RE's Avatar
5 Year Member
Yep, confusing for sure, The top 4 parts for the PCV, bottom 2 for front breather hose :
Old Apr 26, 2020 | 01:13 PM
Paul22RE's Avatar
5 Year Member
You should do all 4 grommets, appears the other front one is also leaking. You can get them in a set along with the 2 half-moons & valve cover gasket. I wouldn't just replace the grommets without removing the cover since there is a chance a piece of the old grommet ends up falling down inside. It is an easy job, just don't over tighten the cover, requires very little torque.
Old Apr 26, 2020 | 01:39 PM
old87yota's Avatar
What did I miss?
What is confusing?
Your confusion is making me confused....
Old Apr 26, 2020 | 02:35 PM
wallytoo's Avatar
the pcv grommet isn't visible in your picture, it is further back on the valve cover, used to seal the pcv valve to the cover. paul is seeing the grommet/seal that is used under the acorn nut to secure the valve cover. there are four of those. i would be surprised if the acorn seal is the source of your leak, rather than the pcv breather hose or the oil fill cap itself.
Old Apr 26, 2020 | 05:21 PM
scope103's Avatar
Originally Posted by old87yota
What did I miss? ...
Commonly, the call-out number on the diagram (12262 or 12263) is part of the part number. Here, hose 12263 had part number 12262-35060, NOT 12263-35060.
Old Apr 26, 2020 | 05:32 PM
wallytoo's Avatar
did you notice that hose, ventilation #2 had callout 12262 w/part #12261-35011?
Old Apr 26, 2020 | 06:49 PM
old87yota's Avatar
True, you are correct as most part numbers do follow this pattern, but I have seen enough part numbers that do not follow that pattern that I just don't pay attention to that correlation anymore.
I am confident that the part number for the breather hose is correct.
Old Apr 26, 2020 | 09:25 PM
Co_94_PU's Avatar
I will go for the trifecta! You PCV hose is probably hard and brittle, your valve cover grommets are old and compromised, and someone has probably spilled oil when Adding.
I dont expect that hose is available any more, I know the RET ones aren't. You might have to cobble together some elbows and straight unformed hoses to replace it.
