Reground cam pics-Would you run it?
Old Apr 15, 2018 | 04:53 PM
parchisi's Avatar
Got this reground cam in the mail a few days ago. Some scoring and a couple nicks as evidenced in the pictures below. I suspect it would probably be alright but would like some opinions before I throw it in. Thanks!
Old Apr 15, 2018 | 05:41 PM
millball's Avatar
Can you feel those with your thumbnail??
Do the journals mike out within specs??? You might give the cam a plasti-guage test on your head to determine actual clearances..
I don't think I would worry too much about the concentric scoring, but I might take a riffler file to any nicks, or dings.
Depending on what you find for clearances, I'd run it.
Old Apr 15, 2018 | 06:53 PM
NYHumpinUtah's Avatar
Let me get this right
You bought this "reground cam' and that's what they sent you? If it were me I'd send it back for a refund!
parchisi's Avatar
Thanks! Yes I will definitely throw some plastigauge on it for what it's worth, was just wondering about that scoring mostly. Slight catching on the thumbnail test on the worst of it but I think I'll give it a go.
Old Apr 15, 2018 | 06:58 PM
parchisi's Avatar
Well, it is a regrind so I wasn't expecting perfection on the journals, I just don't know how bad is too bad. So far I got 1 for and 1 against...
Old Apr 15, 2018 | 07:18 PM
Why not?
If they just did a regrind it should be perfect. I have a feeling that it's not reround just a cam they had laying around. Did you measure the diameters? Are they full size, or undersize?
I wouldn't even bother with it, just send it back unless you're pressed for time
Old Apr 15, 2018 | 07:29 PM
millball's Avatar
Why not?
It's the cam LOBES that are reground. The only way the journals might be refinished would be to weld them up and then regrind to stock diameter. Not cost effective; might as well start with a new billet.
If this cams clearances in the head are good, this cam should serve well.
Old Apr 15, 2018 | 07:37 PM
To each his own
Not in my motor
Old Apr 15, 2018 | 07:49 PM
millball's Avatar
To each his own
Not in my motor
You price a brand new cam that is not chinese slave labor goods and you might change your mind
Old Apr 15, 2018 | 08:04 PM
parchisi's Avatar
I had a 'new' cam in the head before and after 30k the lobes had some bad galling. Not sure if that had to do with the new Chinese cast camshaft or a lube/oiling issue, but that's why I decided to go with a stock regrind this time and see what happens.
Old Apr 15, 2018 | 08:41 PM
How about this
https://www.lceperformance.com/Mild-...-p/1022033.htm
Old Apr 15, 2018 | 11:12 PM
wyoming9's Avatar
Red face
As long as your clearance is within spec go for it !!
etzicle91
Oct 8, 2015 02:24 AM
Strings
Nov 30, 2009 08:53 AM
jlohr
Nov 2, 2008 03:18 PM
Quattro15
Sep 7, 2008 01:38 PM
Yamaha+Toyota=Fun
Apr 4, 2006 05:14 PM
