no power to fuel pump 22re
Old Mar 31, 2018 | 07:04 PM
westjohn's Avatar
what's up guys, been awhile since I've been on the forums since the rise of Facebook and all, anyways, I've got my 86 pickup, 22re, recently saved from sitting for the last 4 years... refreshed the motor, cant seem to get power to the fuel pump, so far I've checked AFM, ohmed good, open circuit relay clicking and ohmed good, can jump power to fuse pump connector under passenger seat and get pump to run, truck will not start,. have changed ECU temp sensor, ECU, coil, fuse pump, different set of injectors, I have power to the injector resistor on passenger fender, what am I missing? with AFM door open fuel pump still doesn't come on, no power to AFM? where does it receive power from? slowly loosing my mind here.... anyone have a link to 86 FSM?
thanks
Old Mar 31, 2018 | 07:52 PM
wyoming9's Avatar
Red face
What happens when you jump the fuel pump check connector ??
On the left fender white black and green wires
All those parts replaced were bad and replaced with new and not Chinese junk??
Old Mar 31, 2018 | 08:07 PM
westjohn's Avatar
My truck doesnt appear to have an diag port... not sure why, also. Parts changed other than ECU temp sensor were known good used OEM parts, when i changed the ECU the truck started for literally 3-4 seconds then died, going to start tomorrow at the AFM and see if i have power there going to fuel pump switcg. Got frustrated for the night, trucks been down for 5 months getting the motor refreshed
Old Apr 1, 2018 | 12:17 AM
RAD4Runner's Avatar
Originally Posted by westjohn
... from sitting for the last 4 years... refreshed the motor, cant seem to get power to the fuel pump, so far I've checked AFM, ohmed good,
...can jump power to fuse pump connector under passenger seat and get pump to run... truck will not start....
... I have power to the injector resistor on passenger fender
There is always 12V to injector resistor and to injectors. ECU provides ground via pins 10 and 20...
...the truck started for literally 3-4 seconds then died...
... seconds after you release ignition switch? What if you keep IGN sw in start position? Still shuts off?
How Circuit Opening Relay Works:
https://www.yotatech.com/forums/f116.../#post52387681
Here's the fuel ump test connector Wyoming is saying above.
Old Apr 1, 2018 | 03:28 AM
wyoming9's Avatar
Red face
Thanks for the picture !!
Sounds to me like the run coil is out of the Circuit Opening Relay from what it is doing
When the start coil drops out the switch opens and the fuel pump quits
Old Apr 9, 2018 | 04:35 AM
westjohn's Avatar
changed fuel pump relay the other day, after it started and ran for a few seconds, it wont do it again, havent messed with it for a few days but fuel pump check connector will be the first place i start, where does the AFM recieve its power from? it appears to be dead as well.
Old Apr 9, 2018 | 08:20 PM
RAD4Runner's Avatar
See how COR works above
Old Apr 9, 2018 | 11:13 PM
wyoming9's Avatar
Red face
I remember you!!
Old Apr 10, 2018 | 01:52 PM
westjohn's Avatar
Checked main circuit relay, ohmed good, im out of ideas here..... i know wyoming! Its been a long time since i was on the fourms!
Old Apr 10, 2018 | 03:01 PM
RAD4Runner's Avatar
changed fuel pump relay the other day, after it started and ran for a few seconds, it wont do it again, havent messed with it for a few days but fuel pump check connector will be the first place i start...
What have you done about the check connector that you said you were gonna do?
Why did you have to replace a part when you have not verified that it is defective? (Pls see signature).
Yes, it is more fun to replace parts than troubleshoot.
What's the main circuit relay?
It ohmed good? Did it Volt good?
repeat: https://www.yotatech.com/forums/f116.../#post52387681
Old Jul 25, 2020 | 02:51 PM
tmartini's Avatar
same same but different
hey everyone first of all thanks for all the knowledge you have bestowed upon me so far im new to yotas and working of vehicles in general with that being said im at my whit’s end i have the same type of problem as the op i have an 85 toyota rwd i thought the pump went out so i tried to replace it but all the bolts on the mounting bracket broke off i (im no metalworker) so i replaced the bracket, pump, tank, and sending unit i got it all hooked up and nothing so i fully charged the battery tried starting the next day and it ran i moved it across the street went to work and after work... nothing so i started troubleshooting the electrical i hooked the pump to the battery and it ran. so i checked the voltage when at the connector for the pump and nothing when the truck is in the on position but then like 10.5 volts while cranking. So I started at the other end and there is 12v after the main relay and 12 after the opening circuit relay. But nothing coming from the 10p connector coming from the ecu. If any one has some words of advice or have had a similar problem please let me know what I can do to get this thing running again I lso replaced the open circuit relay it didn’t help and I know I should have tested before replacing but you live and you learn
Old Jul 25, 2020 | 03:44 PM
tmartini's Avatar
so a couple of things im super dumb and the 10pin connector i was talking about wasnt all the way plugged in lol also the fuel pump isnt connected to it so theres that im not sure what was actually wrong but i plugged in that connector and it fired right up
Old Dec 21, 2021 | 05:40 AM
kadem's Avatar
Hey! I'm having a similar problem my 4runner won't start after a rebuild. Where is the 10 pin connector that was causing your problem ?
JohnDeereJoe
Jul 27, 2020 11:32 PM
bsoccer
May 25, 2020 09:24 AM
Neddus
Mar 8, 2014 03:54 PM
sap4jap
Mar 19, 2009 10:47 AM
cormel
Jan 16, 2009 04:13 AM
