No Power to Fuel Pump Please help!
Old Mar 7, 2014 | 02:56 PM
Neddus's Avatar
Hello,
I have a 1997 Toyota 4runner and My fuel pump is not getting power. I have replaced the EFI relay, CO Relay, After already replacing the fuel pump, so I tested the old one and she spins right up. Now I'm at a loss as my check engine light comes on and it really trys to start but with no fuel it just turns over and over. any advice?? ECU is what i am left with but im not certain my issue. Thanks for any help!
Old Mar 7, 2014 | 02:58 PM
Neddus's Avatar
No Codes are showing so ya before i go buy a junk yard ECU any suggestion?
Thanks all!
Old Mar 7, 2014 | 04:13 PM
mudpunisher's Avatar
make sure the wires are intact. get a multi-meter and actually diagnose it instead of just throwing parts at it
Old Mar 7, 2014 | 05:35 PM
92yoterDD's Avatar
Is it a 22re or 6 cyl?
Old Mar 8, 2014 | 06:47 AM
wyoming9's Avatar
Red face
Just what engine please
You have checked the Fuses 7.5 ignition 15amp EFI
On both the 4 and 6 cylinder engine the fuel pump circuit is pretty much the same.
You checked the your new relays worked?? That they were correct?
The green/Yellow wire grounds the coil of the COR in the ECM
At this point you have checked all connections made sure nothing is corroded.
Fuses are tight in the sockets
Just when did this start??
Old Mar 8, 2014 | 08:40 AM
92yoterDD's Avatar
The AFM is what keeps the pump on and running the once you start. Verify that it is hooked up and working correctly. I had one that would run if I held the afm door all the way open. But if I closed it then it would not supply fuel pump with power.
Old Mar 8, 2014 | 12:06 PM
wyoming9's Avatar
Red face
No AFM in the engines in a 1997 4Runner unless it was an engine swap to a older engine
Old Mar 8, 2014 | 12:35 PM
scope103's Avatar
There's a separate forum for '96+ 4Runners; you might get better luck there.
As mudpunisher says (and the others implied), this is a job for a multimeter. Replacing relays and pumps without diagnosing is a complete waste of time and money.
Old Mar 8, 2014 | 02:59 PM
wyoming9's Avatar
Red face
The poor person posted in the wrong section his second post.
Then has not been back all day
Old Mar 8, 2014 | 03:54 PM
maybe he meant 87?
smthwsn357
May 1, 2024 07:28 AM
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
