Getting hot!
Old Mar 6, 2018 | 07:16 PM
Tate Waddle's Avatar
Getting hot!
Probably a stupid question but here it goes!
Ive got a 92 pickup that has a stock 22RE that is getting hot, I changed the thermostat and flushed the radiator and put the Toyota red back in the radiator. It stopped getting hot for about a week and now it’s getting hot again? Any ideas?
Thanks in advance!
190 degree thermostat is what I put in when the thermostat was changed.
Old Mar 6, 2018 | 08:43 PM
akwheeler's Avatar
not a stupid question at all. You could try burping the air out again, is the coolant still full? another thing to check is your fan clutch. with the engine off try wiggling the fan and then spin it. if it wiggles it's bad, if it spins freely and doesn't come to a stop quickly it's also bad.
Old Mar 7, 2018 | 05:26 AM
Believe that was the issue! i burped it when I flushed the radiator but gues it was not good enough, burped it again this morning and added a little fluid and it didn’t get hot on the way to work. Thanks ak
Old Mar 8, 2018 | 11:43 AM
RAD4Runner's Avatar
Hopefully burping fixes it.
However...
Originally Posted by akwheeler
... another thing to check is your fan clutch. with the engine off try wiggling the fan and then spin it. if it wiggles it's bad, if it spins freely and doesn't come to a stop quickly it's also bad.
Yes, my good and bad fab clutch operation compared here
the1998sr5
Jul 16, 2015 06:20 AM
SDHNTR
Mar 22, 2011 11:34 AM
Skinamer
Mar 9, 2008 12:08 PM
yotarunner
16
Feb 19, 2004 11:42 PM
