zinc
Old Apr 24, 2018 | 07:58 AM
bubbaa's Avatar
zinc
does a 1995 toyota tacoma 2.4 engine need a oil with zinc for the cam
Old Apr 24, 2018 | 05:41 PM
muddpigg's Avatar
I run oil with zinc.
Old Apr 24, 2018 | 05:53 PM
GO_BLUE!'s Avatar
i buy a couple quarts of Amsoil Z-rod 10w-30 and use a quart at every oil change. There's enough zinc in just that one quart to keep you covered. Alternately, you can buy some break-in oil (I like Redline) and put a couple ounces in your crankcase, too, for added zddp. But the Z-rod (comes in 10W-30=yellow top and 20w-50=red top) works better. $12 bucks a quart so it isn't cheap. Also I've had good luck with Archoil, which is boron, not zinc...but essentially works the same.
DON'T put too much zinc (zddp) in there or you will get scoring / pitting on your cam lobs. Less is better.
Zona4r
Feb 28, 2018 08:13 PM
Damian Sanders
17
Jul 13, 2012 09:25 AM
freddy
9
Sep 24, 2009 07:14 AM
TNRabbit
Dec 17, 2007 06:27 PM
