Zinc Anode
Old Sep 13, 2009 | 02:11 AM
freddy's Avatar
Zinc Anode
Is this a good idea?:
Anyone using them?
From their website: (These Flex-a-lite zinc anode kits have developed these kits to be installed in the radiator as a replacement for the drain petcocks. They are designed to protect your cooling system from the galvanic action that eats the zinc rather than the components of your cooling system. Most of today's vehicles have many aluminum parts in the cooling system that may disintegrate from electrolysis on the cooling system. Keep your cooling system working at optimum levels with one of these Flex-a-lite zinc anode kits).
Old Sep 13, 2009 | 06:08 AM
waskillywabbit's Avatar
Perhaps if you don't ever flush your coolant system. Waste of $$$ imo.
Old Sep 13, 2009 | 06:50 AM
freddy's Avatar
ok..... thanks
Old Sep 13, 2009 | 08:16 AM
84YotaBuck's Avatar
They put a ton of them on submarines, see them swapping them out every time one comes in for refit. Must be something to it if our government spends millions of our tax dollars on them....yeah.
Old Sep 13, 2009 | 01:10 PM
vital22re's Avatar
totally a bro
the only time you see electrolysis is from improperly maintained cooling systems. You take care of the service needs of your rig and you wont need things like that.
Old Sep 21, 2009 | 12:28 PM
Matt16's Avatar
What about attaching this to the frame to prevent rust from salt corrosion during winter?
Old Sep 21, 2009 | 08:05 PM
Adam F's Avatar
I do beleive that is why boats put them on. To stop corrosion of the metal from being in the saltwater. Wouldnt hurt.
Old Sep 22, 2009 | 09:15 PM
freddy's Avatar
they are only like $9.00
Old Sep 23, 2009 | 11:04 PM
ESQ's Avatar
ESQ
Cathodic protection will only works if the zinc (anode) is in the electroyte. That is why it works on boats (salt water is an electrolyte), but won't work on your vehicle frame (air is not).
Old Sep 24, 2009 | 07:14 AM
VSU_4runnin's Avatar
make your rig into a boat... then you should need it..
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
Damian Sanders
17
Jul 13, 2012 09:25 AM
TNRabbit
Dec 17, 2007 06:27 PM
crolison
Sep 19, 2007 03:22 PM
