22re random miss
Old Apr 3, 2018 | 05:11 PM
Dirtydavis18's Avatar
22re random miss
I have a 22re that has a random miss after the engine warms up I have added injector cleaner adjusted trmming change distributer cap fuel filter new runs fine don't really notice except idle or lower rpm runs smooth until it idles down and is warmed up anyone have similar issue and what you find out
Old Apr 3, 2018 | 10:21 PM
Co_94_PU's Avatar
Could be as simple as a "cat fire" (reaction of hydro carbons built up in the catalytic converter creating an upstream shock wave), or missing pulse to the ignition system from the distributor sensor (NE signal)..
A little burble here and there isn't something I would worry about.
Old Apr 4, 2018 | 03:49 AM
skypilot's Avatar
Its probably a tune up or bad choice in spark plugs. If its the distributor which from old age is possible, get a Rich-Porter unit. More expensive but apparently they do extra testing to ensure it actually works before shipping out. Its also possible you camshaft is wiped, you have to see if the mountains are hills by now, I know that will do what you describe.
Old Apr 4, 2018 | 10:13 AM
Griswald's Avatar
It might be the Throttle position sensor?
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
SD854runner
Aug 12, 2016 01:40 PM
2000taco
Jan 2, 2012 02:04 PM
Junkers88
Dec 17, 2011 10:24 PM
ozziesironmanoffroad
Apr 18, 2010 12:41 PM
Kiroshu
Jul 23, 2009 02:20 PM
