Random miss going at steady speedany tips?
Old Apr 16, 2009 | 10:17 PM
Kiroshu's Avatar
I have a random miss going do the road at any steady speed it will randomly miss like 5-10 times a min its just lil stumblebut its nothin. runs superb at accel and highway speedsbut randomly misses sometimes and i kinda have changed everything there is to change....
Old Apr 17, 2009 | 08:53 AM
thook's Avatar
What all have you changed, then?
Old Apr 17, 2009 | 09:45 AM
scuba's Avatar
Check your grounds, There should be one under one of the bottom bolts on the intake manifold, and also one on the other side of the block..
Old Apr 17, 2009 | 10:37 AM
Flash319's Avatar
Cracked coil.
Old Apr 17, 2009 | 10:44 AM
Dirt Driver's Avatar
Since we do not yet have a list of the replaced parts, I will add that my truck did that when the O2 sensor was spent. It did it at low throttle and was most noticeable on the highway and at low speeds.
Old Apr 19, 2009 | 07:05 PM
Kiroshu's Avatar
Brand new plugs, wires, distributor cap, rotor button, new coil, new K&N air filter, new oil, Timing set correct, new pcv valve, no vac leaks some new lines, new fuel filter and fuel pump, no oil leaks, no coolant leaks, headgasket good does not consume coolant or oil, new O2 sensor, new clutch........ far as i know grounds are good.... still has random miss
Old Apr 19, 2009 | 07:25 PM
Kiroshu's Avatar
anyone?
Old Apr 19, 2009 | 07:54 PM
Kiroshu's Avatar
Old Apr 20, 2009 | 06:29 AM
Kiroshu's Avatar
Old Apr 20, 2009 | 09:18 AM
Codes?
Old Apr 21, 2009 | 06:16 PM
Kiroshu's Avatar
no codes
Old Apr 21, 2009 | 10:31 PM
Cwaters1184's Avatar
could be a bad TPS
Old Apr 22, 2009 | 02:08 AM
TNRabbit's Avatar
I say it's Obama's fault.
Old Apr 22, 2009 | 11:48 AM
Kiroshu's Avatar
Originally Posted by Cwaters1184
could be a bad TPS
wouldn't it throw a code if the TPS was faulty?
Old Apr 22, 2009 | 12:07 PM
malteserunner's Avatar
Coolant temp sensor
Old Jul 23, 2009 | 02:20 PM
tysen86's Avatar
wow. got the same prob and no one to help with it either.
nvdesertrunner
May 11, 2020 08:18 PM
_Nicco_
Aug 28, 2015 07:26 PM
AndYota
Aug 10, 2015 09:19 AM
shisha1999
Jul 13, 2015 11:09 PM
88runnergomas
Jul 9, 2015 01:12 PM
