fuel tank sending unit?
Old Oct 4, 2009 | 03:40 PM
yoterr's Avatar
anyone know where to get one?? i could have swore i saw it on the autozone website for like $80 bucks but i cant find it, but i did find a universal one for 18 bucks anyone know if it works? says its a 240 OHM empty 33 OHM full, and its for 5-26" deep tanks...im thinkin it might work but i dunno what the stock one is...for 18 bucks i might just buy it and see....
Old Oct 4, 2009 | 05:25 PM
yoterr's Avatar
nooooobody has had a prob with their sending unit??
Old Oct 4, 2009 | 05:29 PM
myyota's Avatar
The sending unit in my 4Runner acts up every so often, so i know its going bad, but i will buy a new one from the dealer, it may cost alot more but at least i know it will work.
Old Oct 4, 2009 | 08:13 PM
yoterr's Avatar
i guess ill be the genie pig for this one lmao
Old Oct 4, 2009 | 08:19 PM
fireman1559's Avatar
what you need to do is pull yours out take it with you to the auto parts store and see what you can find close to it and try it and see if it works that would prolly be your best bet in my opion.
on another note i wouldnt sped 18bucks on one that MIGHT work cause if it doesnt you will need to take it out again! and put your stock one back in
Old Oct 9, 2009 | 11:19 PM
yotaman90's Avatar
Did you ever find one yoterr?
Old Oct 10, 2009 | 12:45 AM
SpecialScottie's Avatar
Are you sure yours is broken? I took mine apart and cleaned it and it works great now
Old Oct 10, 2009 | 01:16 AM
yodamudstar's Avatar
i agree with speacialscottie ive just cleaned mine b4 and it started working have ya opend her up
Old Oct 10, 2009 | 06:42 AM
ayoung101's Avatar
mine continued working up intil the exterior tube rusted through. and then it just pumped gas outside onto the ground, haha. i'm pretty sure i found one through yotatech. post something in the parts wanted section of the classified section.
Old Oct 10, 2009 | 06:46 AM
Team420's Avatar
U can fix the externally rusted line, with some 3/8" steel brake line. I drilled out the old one on top of the sender, then stuck the 3/8" brake line in, welded it to the senser, then sealed with jb weld, then flared it to fit the rubber line. Inside, I connected the 3/8, to the old fuel line, with some rubber fuel hose, and a couple clamps., took about an hour total, and hasnt caused any problems in the 5 mos I've had it like that.
Old Oct 10, 2009 | 11:14 AM
jimep's Avatar
A friend of mine bought a new direct replacement one for about 1/2 of what the stealership charges. If anone's interested I could get you the #. $60 to $80 is alot better than the $140 or more
Eggslinger
Jun 8, 2019 03:32 PM
Doug4320
Mar 24, 2018 10:11 PM
gary4runner
Sep 24, 2015 12:53 AM
skoti89
Sep 11, 2015 07:46 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
