Valve Rocker slightly off Help!
In my rebuild, I placed the rocker arm assembly on and noticed that the rocker cam was slightly off center from one of the intake valves. How can this be adjusted?
i dont even think its possible, but did you put it on backwards?
the arrows are suppose to be facing the front of the engine.
there is no adjustment for the rockers from side to side, they are held to one side by a spring. are the 3 Philips head screws in place and tight? (they probably are just something to look at)
If you rebuilt the rocker assembly, there are a couple of things to check:
There are 2 round spacers located on the intake rocker shaft on either side of the CENTER rocker tower. Make sure they are both there.
If you replaced the rockers with the new Chinese made rockers, we have seen them to be "off" in a few different aspects of the ratios causing odd fit.
Is it off on the adjuster tip to valve side, or the cam side?
Keep us posted
Keep us posted
We just reface OEM rockers only. It takes all of the worry out of it.
wow, ok i can see how it could be out of line if the rocker is crooked lol.. im not a fan of taiwanese stuff either.
its sad that they can sell a rocker that is that messed up.
Dennisx2
08-04-2015 01:26 PM
