no 4th gear whant to fix it!!
Old Sep 27, 2009 | 09:58 PM
juniorg26's Avatar
Exclamation no 4th gear want to fix it!!
i have a 86 4runner 5speed 22re my tranny has no 4th gear what do ineed where can i purchase a kit its simple or not please help also it has a weird sound i belive is the flywheel maybe needs resurface whe i step on the clutch goes away do ineed a new tranny or fix it thanks for reading my ad.
Old Sep 28, 2009 | 05:41 AM
Junkers88's Avatar
What???
Let me see if I can pick some information out of that mess.
When you say you have no fourth gear do you mean you can't get it into gear or when you get it into gear there is no power to the output shaft (no power to the ground)?
The answer to that will let us know which direction to send you for parts or services.
If you have a noise that goes away when you press the clutch pedal it is probably the throw out bearing. I had a similar issue that I fixed by replacing the clutch, pressure plate, throw out and pilot bearings.
Hope that helps.
smthwsn357
May 1, 2024 07:28 AM
montanatruck
Feb 26, 2017 07:07 AM
nick9455649
Sep 11, 2015 05:10 PM
Tykiller1994
Aug 10, 2015 07:49 PM
Jnkml
Jul 6, 2015 01:20 PM
