rattling sound, driveshaft slop
Old Oct 4, 2009 | 01:37 PM
Windsor's Avatar
A couple of weeks ago I started hearing a rattling sound, usually while accelerating (when engine is under load).
With the recent posts about timing chains and "bag of spoons" sound, I thought it was my chain tensioners going out.
It's been getting worse, and the more I listen for it, the more I think it's coming from the rear of the vehicle instead of the front.
Today while cruising down a street, the rattling started, so I put the trans in neutral and killed the engine while the 4Runner was rolling -- rattling continued. Pretty clear sign that it isn't the timing chain.
I pulled it into my garage and slid underneath it looking for a loose u-joint. I grabbed the driveshaft and shook it in every direction but there was no movement.
Then I rotated it and it moved a decent amount (4Runner flat on floor, parking brake engaged). What's the nominal amount of slop here?
Another thing.. I drained the axle (it was full) and put a magnet in the stream to see if any metal shavings came out -- nada.
Old Oct 4, 2009 | 01:47 PM
tc's Avatar
tc
Ujoint - guaranteed. Probably (90%) the rearmost one.
You need to pry on it to see the slop in the ujoint.
The slop you are seeing (rotationally) is the backlash in the gears (both the R&P and the spiders). It can be quite a bit if you have a locker.
Old Oct 4, 2009 | 07:50 PM
Windsor's Avatar
ok, well, I'll swap out both of them since I'm gonna be popping the driveshaft out.
Any gotchas to this? I've done u-joints before, but it was back before about half of yotatech membership was born.
I'm assuming the typical c-clamp and socket trick will work.
Old Oct 6, 2009 | 02:00 PM
Windsor's Avatar
done. I bought the u-joints (toyota parts) and ran it down to a shop to have them rebuild the driveshaft.
$88 well spent for the labor.
Oddly enough, the one by the differential was ok, but the one up by the transfer case was shot -- "the bearings were ground to dust," said the shop owner.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
aowRS
Sep 13, 2017 08:22 AM
Anthony Lee Mathis
Sep 15, 2015 07:22 AM
Streetrod19772000
Sep 10, 2015 06:22 PM
