The paper clip trick
Old Oct 1, 2009 | 02:41 PM
scottydogg's Avatar
Okay, I am new to this board and have been reading on my problem I have been having with my 90 4 runner. It just all the sudden died on me while driving and had to have it towed home. I looked at this site and read on the paper clip trick and it runs with no problems while the paper clip is in. Take it out and it dies.
Now, my problem is I took it to my mechanic and showed him what I have done and he can not find the problem with this. Can somebody tell me please what they have replaced or what they have done to fix this problem. I have tried to locate the cor and all I can see is the computer behind the glove box unless I am looking for the wrong thing. If anybody has a picture of what it looks like, That would sure help me out.
Also if anybody has a part # for a cor so I can order one that would be a great help also.
Old Oct 1, 2009 | 04:45 PM
idanity's Avatar
a link to this paperclip would be nice...hm..
Old Oct 1, 2009 | 05:08 PM
theAuthority's Avatar
User Requested Ban
the paperclip trick? In your computer?
put's it in limp mode. something is failing, a sensor or something.
not giving us much information to go off of.
Old Oct 1, 2009 | 05:33 PM
scottydogg's Avatar
paper clip
https://www.yotatech.com/forums/f116...g-fuel-164551/
Old Oct 1, 2009 | 05:36 PM
User Requested Ban
yah, exactly what I thought.
refer to my above post.
Old Oct 1, 2009 | 05:39 PM
scottydogg's Avatar
clip
What kind of info do you need cause I am in between a rock and a hard place on this. sorry
Old Oct 1, 2009 | 06:30 PM
Jay351's Avatar
So you jumped the fuel pump so it would run??
Old Oct 1, 2009 | 06:40 PM
scottydogg's Avatar
paperclip
Yes I jumped the fuel pump so it would run. If I took the clip out and turned on the ignition, I could not hear the fuel pump. When I put it in, You could hear it run.
Old Oct 1, 2009 | 06:44 PM
Jay351's Avatar
The fuel pump doesnt turn on when you turn the ignition to run. The motor has to be turning over for it to kick on.
Jumpering those connections will make the pump run all the time. Thats why you could hear it.
Old Oct 1, 2009 | 06:55 PM
scottydogg's Avatar
clip
Soooo, Is my fuel pump bad? or is it something else. Sorry for being so dumb I guess but I have no idea what is going on with it.
Old Oct 1, 2009 | 06:59 PM
Skoalbandit's Avatar
not to contradict you Jay, but correct me if i'm wrong. like most other efi motors, with an electric fuel pump when you turn the key on, you hear the fuel pump kick on quick pressurizing the system prior to you starting it... it turns on for about 3 seconds or so. you can hear it every time you turn the key to the on position... is toyota a different system aside from a mechanical pump which will pump the fuel while the motor is cranking... no?
Old Oct 1, 2009 | 07:30 PM
dsmbuddy's Avatar
Check the Fuel pump fuse
Old Oct 1, 2009 | 08:08 PM
Jay351's Avatar
Yeah, on most efi tucks thats how it works. But yes, toyotas are different
I remember my friends crawling over my truck trying to figure out why it wouldnt start, they said it was the fuel pump since they couldnt hear it kick on ohh silly domestic boys haha!
I just read a big topic on toyotanation about a guy having problems with his fuel pump. A member wrote a huge reply and I was going to refer to that for this but I forgot I will take a looksee and post back
Old Oct 1, 2009 | 08:20 PM
Jay351's Avatar
Okey, here you go!
the Circuit Opening Relay that powers the pump is initially triggered by a lead from the STA terminal of the ignition switch - so the pump does operate while being cranked. Once the motor starts, the fuel pump switch in the air meter takes over.
Old Oct 2, 2009 | 10:20 AM
scottydogg's Avatar
pump
Okay, I just checked the fuses and nothing is toast.
Old Oct 2, 2009 | 10:25 AM
User Requested Ban
drive around with the paperclip in permanently. haha...
honestly, no idea dude.. electronics are not my strong suit ..
Old Oct 2, 2009 | 10:34 AM
VTXRider's Avatar
I think my COR is bad too. Tried the clip and it runs fine. I can't find a COR anywhere. Can I wheel it this weekend running off the clip or will I burn something up?
Old Oct 2, 2009 | 10:38 AM
User Requested Ban
It just puts you in 'diagnostic' mode. It shouldn't hurt you at all.
It's limp mode, that new computer cars go into when something stops working, it keeps the motor running.
might get worse gas mileage ?
Old Oct 2, 2009 | 11:00 AM
blueyota's Avatar
same prob
i have the same prob in my 91 pickup but i cant figure it out and have been running on the paper clip for over a year on my dailydriver ...im stumped ...just gona tag along for this one hehe
Old Oct 16, 2009 | 07:53 PM
75TransAmDude's Avatar
So I don't Know if any of you still need info. But check it out. On my freinds 91 Toyota MR2 when you jumper those terminals it turns the fuel pump to max fuel pressure, Thus thats why you do that after you re-intsall your intake and fuel rail so you can check for fuel leaks, and set the timing with pump full blast, I may be wrong but if it were me I would replace your fuel pump.
