deleted balance shafts?
Old Sep 28, 2009 | 04:51 PM
zanzabar0's Avatar
i want to know if this would work on my '94 v6 3.0 dlx. i heard that it is a significant gain in hp but will it turn out to be a good modification in the long run?
Old Sep 28, 2009 | 05:05 PM
90-3vzeslug's Avatar
never tried this, but would imagine the engine would run rougher which could be a bad thing for longevity imho
Old Sep 28, 2009 | 05:47 PM
24Runna's Avatar
Could you explain?
Old Sep 28, 2009 | 06:57 PM
RobD's Avatar
I could be mistaken, and DeathCougar can answer this better than I, but I don't believe the 3.0 has balance shafts.
Old Sep 28, 2009 | 07:30 PM
iamsuperbleeder's Avatar
wth?
I'm lost...
Old Sep 28, 2009 | 08:19 PM
just a 22re's Avatar
mustyoubeatme eclipses and what not the 4g63 motors had them i removed it from there had a ok but shaky idle and was clean up to 7k rpms yes it hit 7k had a lot of work done to it but it didnt last long good for doing it on a drag motor but thats it
Old Sep 29, 2009 | 01:59 AM
TNRabbit's Avatar
I'm aware of NO balance shafts on the 3VZE; I had mine tore all apart & have studied the FSM extensively...
Old Sep 29, 2009 | 04:34 AM
pat161's Avatar
A V6 is a naturally balanced motor and therefore does not need or utilize balance shafts. I4 motors are not naturally balanced so some come with balance shafts, but not all. Even Toyota differs on this, the 3rz 2.7 had balance shafts while the 2rz 2.4 did not.
Old Sep 29, 2009 | 06:23 AM
annoyingrob's Avatar
Actually, an I6 is a naturally balanced motor, and a 90* V8 can be balanced with proper weight on the crank, but a V6 is not. It's close though, which is why you can get away without a balance shaft.
Old Sep 29, 2009 | 06:30 AM
crolison's Avatar
If i ever have to tear into my 3rz i'll do it
http://www.lceperformance.com/Balanc...-p/1015050.htm
kawazx636
Oct 6, 2021 03:03 PM
A2theK
Oct 14, 2015 07:10 AM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
myotherrideisayoshi
Sep 29, 2015 05:41 AM
