Solid or Crush pinion spacer?
Old Oct 6, 2009 | 10:43 AM
Csbauer's Avatar
I tore out my rear third member to replace my pinion seal after an outing and since then i added new bearing and an aussie locker. I added new bearings because of 300,000 miles of use even though they looked beautiful, with not pitting or scratches, the aussie was needed since i get stuck to often when i wheel with bigger rigs.
Anyone know where to get a solid spacer for less the 32.99?
Old Oct 6, 2009 | 10:53 AM
waskillywabbit's Avatar
You want a solid pinion spacer instead of a crush sleeve.
Old Oct 6, 2009 | 11:19 AM
drew303's Avatar
Trail-gear sells them for $19
http://trail-gear.com/toy-diff-setup.html
If you replaced the bearings, you'll wanna check the gear pattern, could have changed and you might need to shim the pinion... worth checking.
solid spacers just take a bit more time to install to set the bearing preload but once it's set you dont gotta worry about it
Old Oct 6, 2009 | 11:35 AM
Csbauer's Avatar
Alright thats a hell of a lot cheaper than at JustDifferentials, and yea i would like to not have to worry about the crush sleeve again. Thanks guys
ashamsuddin
17
Jul 22, 2024 03:59 AM
kawazx636
Oct 6, 2021 03:03 PM
4x4YOTA
Aug 23, 2016 09:08 AM
crash813
Sep 27, 2015 07:15 AM
Odin
Sep 26, 2015 06:56 PM
