O/D Warning Light
Old Mar 18, 2012 | 08:58 AM
bolard's Avatar
O/D Warning Light
I have a new one for you wise yoyatech'ies, I 've finally gotten my 93 4runner on the road, bought it used & not running, Has a 3.0 with A/T , The issue now is sometimes when I start out its very sluggish and the O/D Trans warning light will flash on the dash, I drop into 2nd , it picks up drop back into D , Runs OK , O/D light goes out after a min or so.
Any Ideas? As always Thanks for the Help....
Old Mar 18, 2012 | 10:30 AM
justin_4runner's Avatar
have u tryed pulling the codes for the issue? same as u would for the ecu do it for the trans, count the blinks and look in the book, it will tell u what is going on,
Old Mar 18, 2012 | 10:47 AM
bolard's Avatar
O/D Warning
Thanks Justin I'll ck That, I've seen some say you can use a paper clip if you don't have the correct tester, do you know if this is a proven method? I deal with Murphy (law's) daily,
Old Mar 18, 2012 | 10:51 AM
i usually get a small wire and strip each end and use that, but yes u can also use a paper clip.
Old Mar 18, 2012 | 12:25 PM
bolard's Avatar
Thanks again
Old Mar 18, 2012 | 12:41 PM
bolard's Avatar
Hey Justin, I see your from Tacoma, My wife and I are hoping to move to the Seattle area in Aug, Do you know of any 4 wheel clubs ( Toyota preferred) in that area you'd recommend?
Old Mar 18, 2012 | 01:49 PM
i have not joined or really found any groups for toyota group yet, i have just go with a buddy of mine that has a jeep and i wheel with them. i have not hooked up with many guys off this group.
Old Mar 18, 2012 | 02:28 PM
bolard's Avatar
Thanks Again for the input.
Liadrin
Apr 25, 2022 02:54 PM
BeMiceElf
Oct 10, 2015 09:40 PM
AkitaDog
Sep 1, 2015 08:05 AM
Liadrin
Sep 1, 2015 06:44 AM
Odin
Jul 15, 2015 09:28 PM
