1987 22re Code 11 help
Old Mar 20, 2012 | 07:36 PM
jetpilot's Avatar
I'm getting a code 11 which states: "Switch Signal - neutral start switch ON (22re) or IDL point in throttle position sensor is OFF during diagnostic check".
Can anybody tell me what this means? I've just replaced my TPS with a brand new unit, and pretty sure its set correctly. The problem I'm trying to correct is lousy fuel mileage and inconsistant (and high) idle speed.
Thanks!!
Old Mar 21, 2012 | 06:15 AM
MudHippy's Avatar
It means you have a malfunctioning or misadjusted TPS. Or the Neutral Start Switch is ON during the diagnostic check.
Ruling out the TPS, it means there's a short the Neutral Start Switch circuit. Unless you intentionally switched it on before checking for codes.
montanatruck
Feb 26, 2017 07:07 AM
coreyedwards7611
Jan 16, 2016 06:38 PM
Michael oaks
Jul 27, 2015 11:47 AM
nonstop
Jul 24, 2015 06:29 PM
jake_v
Jul 22, 2015 03:17 PM
