what does this wire go to ?
Old Mar 9, 2012 | 09:17 PM
Dustysmac's Avatar
I'm working on a 1994 22re pick up and the previous owner has disconnected a wire that I'm trying to find what the wire was connected to. This wire comes out of the wiring harness at the same point the the ground wire that connects on the outside of the intake and the last two injector plugs come out of the harness. If there was a plug on it , it has been removed ? Can any one tell me where this wire goes to ?
Old Mar 10, 2012 | 12:47 AM
mpwarfy's Avatar
I wouldn't know if there was a picture but I'm sure if you posted one someone might
Old Mar 10, 2012 | 03:35 AM
rustypigeon's Avatar
what color is the wire?
Old Mar 10, 2012 | 04:09 AM
Dustysmac's Avatar
What remains of the end of the wire is black, the wire is inside the thin black tubing, it feels like there is more than one wire in the tubing . I think the the other wire is broke off inside the tubing.Its directed toward the cab in line with the last injector plug. It's not the starter wire and the truck will run without the wire.I replaced the head gasket and I could have pulled the wire loose but If I did I was not aware of it, I think it was loose when I bought the truck
Old Mar 10, 2012 | 04:33 AM
Bassmastry101's Avatar
If i remember right, I think there was a black wire in the harness like you described that wasn't connected to anything. I could be wrong..I'm looking for a pic. If you post up a pic of the wire in question it will be a lot easier.
Old Mar 11, 2012 | 07:00 AM
Dustysmac's Avatar
I found it , it went down below to the sensor below the oil filter , the oil sensor I think
80Truck
Oct 12, 2025 07:25 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
ToyoToler
Aug 8, 2015 08:43 AM
Daneums
Jul 28, 2015 11:57 AM
TDonkey
Jul 26, 2015 10:14 AM
